This dont look promising
Detonation (or uncontrolled explosion) happens 20* after the plug fires from rapid pressure rise and extreme temperatures. High octane will not stop it if fuel is lean (what usually happens on our rear cylinders) timing is excessive or too much nitrous for a given setup.
what he said ^^^ race gas will help detonation but not if you are lean or have too much timing. switching to race gas often causes you to go lean depending on the fuel. you need to pick a fuel and stick with it and you need to check your tune with that fuel. it is also good to keep the same aproxamate mix of fuels if you are mixing pump gas and race.
11.8 on nitrous, 12.8 on motor..its 110 mixed with 91..it had maybe half tank mixed with 5 gall 110...ive only sprayed it maybe 2-3 times so far with a 175 shot in the new motor..timing is just 26 degrees..no knock..any ways..its gettin some ls6 heads that im gonna have milled with an ms4 cam..traded off the nitrous kit too and hopefully by the end of the summer ill have a direct port plumbed up
