Does this Sound Safe?
Old Jul 27, 2011 | 07:09 AM
bgray's Avatar
TOTM: June 2007
Default Does this Sound Safe?
Im waiting for my Tune to come from Black Bear, however in the meantime Im wondering if it will be safe to start my truck, just for idling and checking for leaks purpose since the swap.
My tune is setup for my old
Setup which is
:5.3L
8.1L NON MArine Injectors - belive 31# pounds?
Long Tubes
Crank Pulley
Full Bolt Ons
Comp Cams 212/218 114lsa
Springs and Rods
So Basically Fully Bolted with a Cam
Built(i was told) 4l60e
New Setup Basics.
Lq9 6.0l
PRC Stage 2.5 LS6 Heads
Dual springs and Rods
TSP Torquer 3 231/234 111lsa
Marine Injectors #42? inejctors
Long Tubes
Crank Pulley
Intake
FAST LASXRT
102mm Big Mouth TB
I wanna be able to start the truck, run the fluids, check for leaks etc, not driving it more than one bay to the next.
Does everyone think its safe to run that in the meantime?
thanks
Old Jul 27, 2011 | 08:57 AM
zeake's Avatar
I would attempt it but no throttle at all.
Old Jul 27, 2011 | 10:35 AM
Mangled03gmc's Avatar
Baltimore Whore
I think you will be just fine
Old Jul 27, 2011 | 12:03 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
yeah you'll be fine we started my buddys heads cam 5.3 on his stock tune only problem was it didnt idle worth a **** .
Old Jul 27, 2011 | 01:43 PM
bgray's Avatar
TOTM: June 2007
check back for lumpiest cam video ever later
Old Jul 27, 2011 | 02:35 PM
Bumpers's Avatar
it should but I told you my only concern on gmfs..
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
carid
Oct 1, 2015 09:22 AM
Rockrz
Sep 29, 2015 09:07 AM
