Does the Comp 212/218 high lift cam have advance ground in?
Old Nov 13, 2004 | 07:28 AM
onyx's Avatar
14 Second Truck Club
OKOKOK.. seriously... explain...
i know what duration and lift is....
what is Lobe Center Separation and Intake Centerline ????
...and what is advance ground in?
Old Nov 13, 2004 | 07:45 AM
Sport Side's Avatar
See if that helps.
The LSA is the amount of degrees between the Intake Centerline and Exhaust centerline.
Sorry, I had to retype that...
Old Nov 13, 2004 | 07:48 AM
onyx's Avatar
is it good to have a bigger, or lower overlap?
Old Nov 13, 2004 | 07:53 AM
Sport Side's Avatar
With your radix less overlap.
Most of the camshafts being used are in the negative range. Less than X amount of overlap. And low boost at that.
Take the 212/218 @ 114lsa. It has -13* of overlap relative to top dead center. The exhaust valve closes 7* before the piston reaches the top. And the intake valve opens 6* after the piston has reached the top. So theres a gap there of -13* of overlap.
So worrying about overlap with a smallish camshaft shouldn't be a big concern. Obviously, there wont be any bleeding of boost if there isn't really an "overlap" phaze.
A 220 @ 109 has 1 degrees of overlap relative to TDC.
A 220 @ 113 has -7 degrees of overlap relative to TDC.
Up to the cam grinders to decide when they feel the need to back down overlap in fear of bleeding.
Old Nov 13, 2004 | 07:56 AM
onyx's Avatar
ahhhhh... so since it is letting in more air, you want more flow of fuel to even it out?
Old Nov 13, 2004 | 08:01 AM
Sport Side's Avatar
A 220 @ 109 has 1 degree of overlap relative to TDC.
Old Nov 13, 2004 | 08:11 AM
Sport Side's Avatar
Eh, I might have confused you.
http://www.chevytalk.com/tech/101/Cam_Theory.html
try reading thru this. its a bit detailed....let me search some more. i know j-rod has some good basic tech on camshafts.
Old Nov 13, 2004 | 08:43 AM
one03sierra's Avatar
Formerly one92rs
Talking
i think with a radix or F.I. you want no less than a 114 lsa. i think they made good power with a ls1 119.5 lsa cam.
Old Nov 13, 2004 | 02:31 PM
Ryan23silverado's Avatar
Not picking on you, but this is why I posted that picture in the cam thread. A lot of people on here think that lsa means over lap, but it does not
Old Nov 13, 2004 | 02:33 PM
I found this, but I'm not sure if it works...
"If you have the duration at .006,add the intake and exhaust duration,divide by 4,subtract the LSA and multiply by 2,that will give overlap."
