the difference between 4.8, 5.3, 6.0
Old Jan 17, 2003 | 04:15 PM
jr4x4's Avatar
Default the difference between 4.8, 5.3, 6.0
i know these three motors are built on the same block, but whats the difference in the parts that make them up? could i build a 6.0 by swaping parts?
Old Jan 17, 2003 | 04:24 PM
speeder_08's Avatar
Default Re: the difference between 4.8, 5.3, 6.0
a friend of mine from texas had the same question and he ended up dropping a 6.0 in to replace the 5.3 so i would guess there is a significant difference. if that helps answer your question.
Agapito "Speedy" Gonzalez
Old Jan 17, 2003 | 05:12 PM
BigTex's Avatar
A 6 liter has a different block with a 101.6 mm bore. The 5.3 and 4.8 have a 96.01 mm bore. The 5.3 and 6.0 share the same stroke with crank and rods. The 4.8 has a short stroke.
You could turn your motor into a 6 liter if you got a new block and pistons. Heads are different as well.
Old Jan 17, 2003 | 05:44 PM
GREGGO's Avatar
This should explain everything for you.
GM POWERTRAIN
Greg
Bumpers
Aug 4, 2024 09:44 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
