Difference between......
Old Jun 29, 2006 | 11:44 AM
BlownChevy's Avatar
blownerator
25 Year Member
Default Difference between......
Mass Air Meter vs. an Air meter......
Just checking to see of people know the difference.
Old Jun 29, 2006 | 11:58 AM
dewmanshu's Avatar
Moderately Differentiated
are you talking specifically for the purpose of metering the incoming air to your engine, or at least your ECM doing so? Then i'd say mass is using heat resistance and air meter is an actually phyiscal device that measures air by movement (the worst in accuracy IMO, like a weather vane's physical resistance being measured).
Old Jun 29, 2006 | 12:01 PM
BlownChevy's Avatar
blownerator
25 Year Member
Exactly
Old Jun 29, 2006 | 12:39 PM
vanillagorilla's Avatar
There are hot wire anemometers that just measure the velocity of the air using thermal resistance, with no ability to measure the mass of the air. So by saying that just heat is used to measure the mass of the air is incorrect. Other things need to be held constant in order to meausure the mass of the air.
Old Jun 29, 2006 | 12:43 PM
budhayes3's Avatar
PT's Slowest Truck
I'm used to the hot wire design as being referred to a Mass Airflow Sensor, and Mechanical Designs (like Toyota's older design that had a flap that opened and closed in conjunction with a variable resistor, like a rheostat) being referred to as an Airflow Meter.
Old Jun 29, 2006 | 12:44 PM
dewmanshu's Avatar
I was just being simple, even though if you wanted me to be complicated I still wouldn't of said that, over my head. LOL
twake_410
Apr 14, 2016 09:58 PM
wickedRCSB
Oct 30, 2015 09:45 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
