damn tq converter bolts :mad:
Old May 1, 2004 | 07:54 PM
dubrado's Avatar
Default damn tq converter bolts :mad:
damn near stripped them completely w/the allen, still wont come off
Old May 1, 2004 | 08:10 PM
OBXMarine's Avatar
Tell me about them!!! I had the same problem. Try a Torx bit. I was able to get two off using it.. Iit took me a dremmel tool and a few hours for the last one.
Old May 1, 2004 | 08:17 PM
L-EATER's Avatar
11 Second Truck Club
Try a 6 point 15mm socket. That is what I always use-those allen heads strip out too darn easy.
Old May 1, 2004 | 09:01 PM
revolution's Avatar
word - i used a 15 mm socket 1/2 driver, came right off! remove your starter (if you havent already) - its easier.
Old May 1, 2004 | 09:33 PM
1TRUESS's Avatar
Why would you even use a Torx bit when you can use a socket? Just wondering! I have never had any luck with Torx bits. I never understood why people use an open box wrench when they can use a socket either. Just does not make sense to me. Not trying to put any one down, I just don't understand why someone would do it the hard way.
Use a socket!
Old May 1, 2004 | 11:45 PM
dubrado's Avatar
Use a socket!
can't use a socket when the bolt head is round
might have to weld on another nut and try to get them off or cut that **** off
which i'm willing to do
Three6GMC
Aug 28, 2015 07:56 AM
signguy62
Jul 25, 2015 03:12 PM
Deceptarado
Jul 8, 2015 05:24 PM
