D-max intercooler going in tommorow!!!
Old Nov 13, 2004 | 07:11 PM
  #61
Jason 98 TA's Avatar
FormerVendor
Anyone ever decide if this thing can install in a 04 Silverado 1500? I think I may need to run that with my STS
Old Nov 13, 2004 | 08:04 PM
  #62
Starting the install monday. Will have some pics along the way.
Old Nov 15, 2004 | 03:52 PM
  #63
Chevmann99's Avatar
I am very interested in this, can't wait to see pic's. I finally got a chance to look a deisel over pretty good this weekend. Even for a 2500HD swap it looks like I would need at least the Deisel radiator & fan shroud in addition to the intercooler. Possibly would have to switch to electric fans depending on clearance. It looks do able though. Just need to price the parts.
Old Nov 15, 2004 | 04:14 PM
  #64
Green Thunder's Avatar
I have a duramax radiator Brand new I will sell for $400.00 shipped..
Old Dec 15, 2004 | 05:34 PM
  #65
FormerVendor
Anyone ever complete the install on a 04 truck?
Old Dec 16, 2004 | 02:11 PM
  #66
hefdaddy007's Avatar
nope will be a little longer. sorry for the wait i'm waiting on my money for the turbo.
this is not a direct drop in by no means.
Old Dec 16, 2004 | 11:19 PM
  #67
(Ken)-96GMC K1500 SC's Avatar
No one else has done it as far as i can tell, so me and a buddy are putting one in. Got it at the dealer for $350.
This thing is one huge MOTHER-******!!!!!!!!!! Should get some really cool IAT's.
Anyway, here's the pics. We will take photos along the install and post them up tommorow night. If one of the mods could "Hostem & Postem" that would be great.
You know I looked at installing one of those on my truck but it seemed way to long....decided to use a 7.3L turbo diesel intercooler as the Howe and flex-a-lite would fit perfect inside it...
Runs at ambient temp down the road and temp only goes up a few degrees above ambient under boost conditions...like a 95% effency ratio or better! at 8 psi of boost on the old 350 engine I only lost .5 psi through this intercooler!
With built 383 I am seeing 6psi of boost with the 3.33" pulley after the IC.
7.3L Ford turbo diesel intercooler with a 30" Howe radiator and 295 dual fans...I have a tech article on the FSC site with lots of pics.
You got to be a member to see it though
http://www.fullsizechevy.com/forums/...ad.php?t=12897
Ken
www.kctrading.net/sierra
Old Dec 17, 2004 | 07:34 AM
  #68
Thats a nice set up there. Cant wait to see what the new engine will run.
Have you ever thought about buying some rear wheel spacers to get the rear tires out to match the front? I put some on my Blazer and it made it look alot better.
Old Dec 17, 2004 | 09:01 AM
  #69
Actual they are about equal...the 14 bolt rear end is about 1" wider than the stock 10 bolt....I'm also the kind of guy that does not like the tires sticking out much past the fender wells.
You are going to have to post a tech article when you get that IC installed! I think I was the first one to try installing a 7.3L turbo diesel intercooler on my GMC but I've seen them use this same IC in other cars and vans!
I've got 500 miles on the 383 now...my boy and I went for a test drive last night and got on it from 1st to 2nd and the SC puts out a solid 6psi of boost after the IC with the 3.33" pulley...lit the tires up on the 1-2 upshift more than it did before and this is at 2200 elevation. No pinging or funny noises I had to actual lean it up a bit on the base fuel to get the LT fuel dialed in...went with +10% more fuel at WOT along with the SFMU. More boost should be handled with adding more fuel pressure...I've got 25psi more to spare there.
Still getting use to the engine and tranny poly mounts...how much more vibration with the trans mount? Was thinking of putting that one back to stock.
Ken
Old Dec 17, 2004 | 11:21 AM
  #70
NXRICKY's Avatar
Former Vendor
Fpund this thread thought I would post it here also.
Just finished trying to install this intercooler in my 2002 6.0L HD. This cooler did not fit my truck. It is just to wide and front core supports hit on the driver side and the ac hose (hard lines) hit on the pass side. Has anyone got these to fit yet and if so could you post some pics or just send them to me. I am just about to order a custom cooler that will go in just behind the grill.
Ricky
