Current draw
Old Dec 30, 2004 | 02:34 PM
Default Current draw
Someone - refresh my memory
What is considered excessive current draw ? 0ver 15 miliamps ?
Old Dec 30, 2004 | 05:31 PM
parish8's Avatar
single digit dreamer
ahh, yeah, thats it
what are you talking about? a little more info might help.
Old Dec 30, 2004 | 05:41 PM
alternator??
Old Dec 30, 2004 | 08:31 PM
wrencher's Avatar
wrencher
Allowable parasitic drain is approx. 50 milliamps.
Old Dec 31, 2004 | 12:10 PM
slowec's Avatar
A truck should only draw around 7 to 12 . 25 would kill a weak battery in a long weekend . Make sure the computer is going to sleep for your readings.
Old Dec 31, 2004 | 01:41 PM
wrencher's Avatar
wrencher
>.25 would kill a battery in a night, that is 1/4 of an amp. The most you can have is .050 amps, look it up that is the allowable spec. It would take .012 to keep pcm & related modules memory & a clock/radio alone......
Old Dec 31, 2004 | 03:34 PM
my 91 is killing the batt overnight
I tested the alt - I thought I had a recifier problem
I have to break my fluke out and see what my draw is.
Something is killing the batt
Old Dec 31, 2004 | 07:33 PM
NovaTime's Avatar
50 mA is still a lot of current for an automotive application. Are you running any kind of external devices that could be hot (+12v) when the car is off?
Old Dec 31, 2004 | 07:39 PM
NovaTime's Avatar
if you've got any external devices installed it may not be a bad idea to use a 30A relay.......
Old Dec 31, 2004 | 07:49 PM
Stroker 1500's Avatar
i always thought 25 mah parasitic draw was the max
