crossroads on head selection
I have a 370 short block on the stand it consist of wiesco flat tops with 3.2cc reliefs callies rods and factory crank. Its going in a rcsb backed with a 4l80 and 3500 ish stall plan to drive it on the street more than anything. I had planned to run PRC 250cc ls3 heads milled to 64cc to put me around 11:1 comp. I already have a cam for the square ports 235/251@.050 .621/.624 113.0 recommended by a local builder. After some reading I am having second thoughts that I am going to give up too much low end with the square ports over a cathedral port setup. I will be sprayin it whatever it takes to run 10.50s up to 300 total. Any opinions or recommendations would be greatly appreciated as I cant make up my mind and the more I read the worst I get wrapped up in different ideas.
thats not a bad cam they must of designed it around the nitrous the lift could go 621 or 624 across, i'd say this i'm a big fan of the ls3 heads i run them on my 408 and they flow very well but you can get the same effect out of a set of 243/799 heads with lots of port work
11:1 compression is a nice sweet spot and still run pump gas i did it for years on a stock bolted 6.0, just make sure the valvetrain is setup right whichever way you go, personally dont like the stall speed but thats just me im more into the big stalls specially a triple disc cause with the right tuner its easy on the street. either had will give up or gain anywhere in the powerband it all depends on how all the other parts are setup and chosen
specially if youre spraying it then i wouldnt worry so much about low end but then again thats just me
what intake you plan on running ?
what header size & exhaust ?
whats it going in ?
lay it out on paper, think about how much you wanna spend
then choose wisely
whats it going in ?
then choose wisely
whats it going in ?
then choose wisely
whats it going in ?
then choose wisely
I was hoping you would chime in. Did you ever run the LS3 heads on the 6.0?
Headers are tsp 1 7/8 fbody headers into mandrel 3" with an xpipe and spintechs in the back.
As for intake was thinkin either hi ram or victor jr. with a 4 barrel throttle body
It's going in a 99 rcsb
yes i ran the ls3 heads with the hollow and sodium valves, very light, i wouldnt run the l92 valves theyre to heavy specially when you wanna turn around 67-7k rpms . i ended up floating a valve at 7200 rpms they were the prc springs if not mistaken and yes they were double springs.
nice header choice should be fine, that single exhaust or dual though?, i rather have duals., i ran the FAST car style intake and loved it worked very well with my setup, personally i'd like to try the holley mid intake, i run the holley high ram as of now, shooting for 10.xx on motor been 11.0x so far todate.
mind you my truck weighs in now at 3950 with me in it.that 99 rcsb if its the WT package i personally thing you'll achieve your goals pretty easy, i was hitting low 10.3-5 on a 150 hit.
It's duals exiting together over the axle. I would use hallow stem valves with the prc 250s and probably Manley nextek springs. My truck isn't a wt model it's all electricity still a hopefully going to stay a street truck but I'm sure you know how that goes lol. I will look into the holley mid ram I wasn't aware of that intake thanks for the heads up. Your truck runs great and looking at your build has come a long way. Looks like your real close to the 10.xx mark too will be anxious to see what some cooler weather may do for your times.
thanks for the kind words never really never expected to take the truck as far as i did, i was really happy with the stock lq9 shortblock fully bolted but once i floated the valve and the funds were available it was 408 time, its very stout but sometimes i wish i would have left well enough alone lol!! it is what it is and one day she'll she her full potential i know alot of sponsors are waiting ! shes an easy 9 sec truck the only mod i really have left is the 9" rearend which will be coming soon as of now its just getting some cosmetics done as far as custom gauges and such.
I looked they don't offer a square port mid ram at this time. And yes I would let a pro set the heads up once I find someone in the Houston area . The heads are cnc ported and the intake runners are 10cc smaller than stock but they flow more than stock ls3 cnc'd heads
Hopefully I can catch you at the track sometime and check your truck out and see a couple runs. How do you like the coil overs up front?
I went 10.6 in an extended cab with 10.6:1 370 with stock l92 heads, Vic jr, 4150 4 barrel throttle body and .060 jets in a nos crossbar plate. Everyone says you lose low end torque. I was cutting 1.61 60' then, now I'm cutting 1.59 60' with a bigger cam.
