Crossover pipe search
Old Aug 29, 2014 | 02:51 PM
MonkeyRench's Avatar
Default Crossover pipe search
I have a 2003 RCSB 4x4 4.8 and I am in need of a crossover pipe. The cats went bad and a hack job was done to replace those with pipe. The original crossover is no longer any good.
My question? Is there a company that makes a crossover pipe without the cats installed that bolts up to a full stock system? I still have the stock manifolds on it still and really don't want to go the full header combo yet. I know the junkyard will sell me a cross over but it has the cats and they want a lot of cash for that thing. I was hoping there was an alternative out there.
Old Aug 29, 2014 | 03:17 PM
ezdaar's Avatar
cheap *** pacesetter modded for oem manifolds?
Old Aug 29, 2014 | 03:45 PM
JohnDaMan's Avatar
http://www.jegs.com/webapp/wcs/stores/servlet/m20ProductDisplayView?pageSize=10&resultCatEntryTy pe=2&searchTerm=&catalogId=10002&langId=-1&productId=348962&storeId=10001&sType=&pgGrp=sear ch
That one is on my 2000. Don't see why it wouldn't work for yours
Old Aug 29, 2014 | 05:43 PM
Thanks, I will keep those in mind. I don't see why they wouldn't fit either but $200.00 is hard to spend without knowing why it only shows 2000-2002. Clicking on the applications menu shows 1998-1999. Wonder why they show different years for applications. I may have to do this though if nothing else comes up.
Old Aug 29, 2014 | 06:24 PM
Jason Z69's Avatar
Whats ur location. I have a real good exhaust guy
Old Aug 29, 2014 | 07:06 PM
I'm in MI. Thanks though. You would think that there would be plenty of good exhaust guys around here. Most shops look at you crazy when you ask for your exhaust not to be made of kinked pipe. Any shop that will bend it will charge enough for a header combo setup. Unless someone around in MI knows someone.
Old Aug 29, 2014 | 07:57 PM
FFDP's Avatar
I have a factory Y-pipe with no cats from a 2001 4x4 Z71 truck sitting around. I couldnt use it on my truck as it didnt fit because it's 2wd. I'd think it would fit yours if you wanted it. Shipping would be kind high but would be cheaper than most other routes. It only needs 1 weld to put it back together, it was cut to make shipping easier. If you perhaps want it, you can let me know.
Also from the previous post above, I run that same jegs offroad y-pipe on my 2006 sierra 2wd, but it does leak from the back flange currently. Otherwise it was a straight forward install.
Old Aug 29, 2014 | 09:13 PM
JohnDaMan's Avatar
Hey if it doesn't work you can just send it back to Jeg's. Their return policy is pretty hassle free. Mine doesn't leak at all and has been on for about 4 years
JordanH
Sep 12, 2015 12:02 AM
sTNT971
Sep 11, 2015 02:38 AM
chevstang421
Sep 10, 2015 09:16 AM
pewter00
Sep 7, 2015 10:14 PM
