crankshaft spacer
i have a 2000 4.8 with the nv3500 it has a longer crank im getting a 02 lq4 that has the shorter crank my problem is with the nv3500 work with the spacer or will the input shaft going to be to short and not make it to the pilot bearing if any ones has answers on this need it right away
Not sure if this helps, but I believe that only the 6.0's had the longer cranks in 99-00, while the 4.8-5.3's were the same on up through 07...I think that if you use the flywheel from your 4.8 you'll be OK, hopefully someone who knows for sure will chime in.
calsdad
Jun 14, 2023 11:07 PM
