Could use some advice. bump the 4.8L or dump it.
Old Oct 8, 2018 | 03:41 AM
0utlawe's Avatar
Registered User
Smile Could use some advice. bump the 4.8L or dump it.
Hello I have a 07 classic 4.8l silverado and I'm completely lost when it comes to specifics, I can turn a wrench but need direction.
I was thinking about doing a head, intake manifold, TB, cam, exhaust, upgrade and I am clueless what motor it is, (due to it being a 4.8 and I'm new to this)
Is the 4.8 compatible, what are the pros and cons?
Or should I even do all that or just swap to a 6.0 and do all the mods while I have the motor out etc.
build internals and do boost?
I'm not sure what direction I should go but I know I wana go fast.
Any advice is appreciated thanks!
Old Oct 8, 2018 | 03:47 AM
stock48's Avatar
9 Second Truck Club
Id save the $ and trouble and go with the 6.0L unless you plan on boosting the 4.8L.
Old Oct 8, 2018 | 01:16 PM
terravast4's Avatar
boost that 4.8 or go 6.0
Old Oct 8, 2018 | 01:26 PM
arthursc2's Avatar
I like the 4.8!
For cars and lightweight buggies with a rev happy cam
I agree with the above, or put a roots on the 4.8
Old Oct 8, 2018 | 03:52 PM
BudRacing's Avatar
Don't bother with the internals on an 07 4.8. I'd go straight to boost with a suitable cam. However, keep in mind that you'll also need to upgrade the trans... and fuel system. It adds up quickly for a reliable setup. The 4L60 won't take much abuse, but if you are going to mess around with either trans, make sure to drop it into 3rd.
Old Oct 8, 2018 | 08:53 PM
0utlawe's Avatar
Registered User
So I'm now debating boosting it with 8-9lbs of boost. I found a surprisingly cheap kit from these guys, https://www.on3performance.com/shop/...-turbo-system/ It mentions it is compatible with the 4.8, I see that I will need to upgrade the fuel system. And trans as BudRacing mentioned, But shouldnt a motor at 160k miles get a top end refresh when putting boost to it? and also what else should I do to keep it a happy motor taking 8lbs. I got this truck at 140k and changed the oil every 3k miles, very clean motor. was highway miles before me.
Edit:
Originally I was going to lift the truck 6" +3" body lift, put 37" tires and 22" wheels but after adding it all up I realized there are two roads I can take at this point, Eat *** and go fast or ride high and slow as hell!
I'm liking the boost idea the most and so far it's actually cheaper than what I was originally going to do.
On 3 turbo kit with fuel system upgrades etc : $2,898
New trans that can handle the new abuse : $2,200 - $3,000
Waiting on recommendations for what else I should invest in to make this build more reliable.
Old Oct 8, 2018 | 09:24 PM
FFDP's Avatar
You'd be better off going with a different turbo kit, they On3 kits can work but have a few flaws that make them more of a hassle to deal with. More money up front for a better fitting kit makes your life easier.
If the engine is healthy you really do not have to touch a thing if you aren't opening it up. If you add a camshaft then stronger valve springs is a good idea or if you plan to run a alot of boost the stronger valve springs on a stock setup wouldn't be a bad idea.
Turbo kit, 60lb/hr injectors, 340-450lph fuel pump, 2 or 3 bar MAP sensor, custom tuning and that's kinda all you need to run 8-12psi.
Old Oct 9, 2018 | 08:49 AM
BudRacing's Avatar
KB Racing and Trick Turbo are two other good kit options. I like Trick's cast manifold.
Old Oct 9, 2018 | 10:12 AM
arthursc2's Avatar
Roots blow it.
No questions asked
Old Oct 9, 2018 | 01:26 PM
terravast4's Avatar
^^^^^^yep....even a used baby mp 112 will kick some ***
