corvette servo number for transgo?
hey guys, in the instructions, it says to look for the last 3 digits on my servo to see the recommended spring for the accumulator. or something like that.. i use either a red or white spring depending on number. can you guys help?
I have billets so I can't help too much. It does mean on your stock servo's there is a number on there, that will tell you what spring to use. Call me if you have any other concerns. I tried to call you back to check if the fax went through ok, the number is set up for fax, so I couldn't get through.
