Corvette Servo Installed
Old Sep 19, 2004 | 06:53 PM
KySilverado's Avatar
Default Corvette Servo Installed
Finally got around to installing KDS bought vette servo's today. Just the 1-2 and did not install any shims from the Transgo kit I also have. Took me about an hour with not major problems. Good thing the kit came with all the o-rings and seals. I needed a couple of them.
What I thought was TM in my truck now appers to mostly been slip from 1 to 2nd shift. The servo definatley firmed up 1 to 2 and 2 to 3. My truck only has 20K miles on it and the 1 to 2 shift was horrible at WFO but firm anywhere else. Its now firm both part throttle and WFO. I wouldn't want any harder shifting.
According to G-timer I gained .1 second quarter from 14.40's to 14.30's in 4wd launches. 0-60 times show the same. 6.0's to 5.90's.
Figure I'll hold off on the transgo kit until I get a tune with TM reduced/removed.
Old Sep 19, 2004 | 07:00 PM
F8L Z71's Avatar
Good to hear.
I always wanted to try one of those but never got around to it.
Try and figure out a way to launch under some boost and watch those 0-60 times drop like a rock. On 5-6psi (at launch) I was getting 0-60 times in the 3.7-3.99 range. Granted I'm running more boost but you get the idea. It's fun as hell
Old Sep 19, 2004 | 07:21 PM
Originally Posted by F8L Z71
Good to hear.
ITry and figure out a way to launch under some boost and watch those 0-60 times drop like a rock. On 5-6psi (at launch) I was getting 0-60 times in the 3.7-3.99 range. Granted I'm running more boost but you get the idea. It's fun as hell
You're right. I'm not holding the brake to build any boost. I should be able to build all that I can 5-6psi in 4wd and launch. Even with the stock converter. Tried it couple times in 2WD and just smoked the tires through 1st and half of second. I'm still a bit leary of torquing it up in 4WD. Bit afraid of breaking my daily driver Will soon though
Old Sep 19, 2004 | 07:23 PM
F8L Z71's Avatar
I hear ya mate
Just make sure to get it on video if you do. It's a pretty bumpy ride
Old Sep 19, 2004 | 07:39 PM
I hear ya mate
Yeah, saw your video, sick stuff. I'm used to rear wheel drive launches and wheel hop, gonna take this AWD stuff slowly. Just the torque steer I feel in the launches I'm doing is unsettling. If I get wheel hop from one side to the other in the front I'm really gonna be back peddling quickly.
Old Sep 20, 2004 | 10:17 AM
TigerFan187's Avatar
I dio the Transgo +vette servo 4-5 months a go and I love it! I used one washer in the 1-2 accum and I can bark second If I get on it. It was well worth the money plus it helped out with me being abe to remove TM a little safer!
Do it!
Old Sep 20, 2004 | 02:55 PM
Where do you live in ky.
Old Sep 20, 2004 | 04:41 PM
Salvisa
Old Sep 20, 2004 | 06:55 PM
Salvisa
Not far from me. Casey County here.
Old Sep 20, 2004 | 07:22 PM
Down that way from time to time, riding the bike at Sharpe's. Don't think I could miss you if I saw your truck. I'll give a honk if I see ya.
