corvette engine in a Tahoe?
Old Nov 18, 2010 | 10:07 AM
Sotorin's Avatar
Default corvette engine in a Tahoe?
Can a corvette engine be put in a Tahoe? Is this something that I can just go for or are there any possible problems I should be looking for?
Old Nov 18, 2010 | 10:08 AM
Atomic's Avatar
I have a gauge for that
Guys do it all the time. What year is your tahoe and which vette engine are you considering?
Old Nov 18, 2010 | 10:20 AM
TX Tahoe Z71's Avatar
Hmmm, fast Tahoe competition, I don't like it!
JFWY!
Look at the iron block 6.0's as well, usually a bit cheaper (leaving money for a cam, long tubes, etc) and a proven engine.
Old Nov 18, 2010 | 10:23 AM
pewterliftedz's Avatar
yup. the easiet way is to use ur serpentine set-up and intake.. but like atomic said, what yr tahoe and vette.
Old Nov 18, 2010 | 11:20 AM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
There was a guy from Louisiana with an LS1 in his Tahoe that was at the Jackson gtg last month, I don't remember his name though. May be one of the LA guys will chime in & give his screen name.
Old Nov 18, 2010 | 11:38 AM
Sotorin's Avatar
Currently I have 07 but this is not the one I'd like to have that engine in. This will be 01-06 Tahoe (LS model preferably - don't know if this matters). There are few sellers from whom I'm considering a purchase solely for modding purposes. I already have new TVS1900 in storage waiting to be installed. Will I have compatibility issues with that supercharger on a corvette engine? There is LS7, brand new engine for sale on Ebay. This is kind of expensive and I'd much rather buy from someone here in the community.
Old Nov 18, 2010 | 12:06 PM
GMCtrk's Avatar
The LS7 isn't a direct swap, LS1/LS6 are direct. LS2 is not direct either.
Old Nov 18, 2010 | 12:31 PM
THE-HOE's Avatar
Like they said, it matters what vette engine you want to use. If you want to use the ls2 you have to change/ re-wire things like knock sensors, and cam position sensor. Also the ls2 would have to be a earlier year one so it has the 24x. If you were to use an ls1 everything would work fine, like said above, easiest to use your intake manifold and front accessories off of the Tahoe engine.
Old Nov 18, 2010 | 12:47 PM
grey matter 04's Avatar
13 Second Truck Club
yep thats kyle who had the tahoe at the PT meet
its now rockin a new cam that sounds mean
Old Nov 18, 2010 | 01:08 PM
Lucille's Avatar
Can be simple or complicated depending on your goals. I put an LS3 into a 03 Avalanche. Due to the L92 heads my intake wouldn't work - when I changed out the intake my accessories wouldn't work - when I changed out the accessories I had to notch the passanger side frame to keep the AC. Not to mention having to mount and wire the 24/58x reluctor converter box.
