corvette 02's
Old Sep 16, 2009 | 09:37 PM
soon2befast04's Avatar
Ok thanks guys I noticed my truck was idling a little rougher in the mornings since the header install? had the same problem with my T.A.? heard something about the coating on the headers messing with the 02's? Oh well it has 90,000 miles so it could prob. use a set anyways!
Old Sep 16, 2009 | 09:49 PM
budhayes3's Avatar
PT's Slowest Truck
Actually the coating will help the O2's as it retains heat and keeps it in the exhaust system, but I could see how your truck may run rougher if not tuned for the headers.
In that case I might be in for a set, I am getting super rich afr's sometimes, the damn truck sounds like it is on a 2 step, untill it clears up, which happens after I pop the gas a few times.. I knew it has to do with heat but couldn't put my finger right on it...
Check your O2 sensor activity, if they're fluctuating from rich to lean rapidly, they're OK. The O2 sensor issues that are common with LT's usually pops a code.
Old Sep 16, 2009 | 09:57 PM
Mangled03gmc's Avatar
Baltimore Whore
Na not getting no engine codes at all or lights.. Just randomly gets a super retarded idle, under light driving, but heals up within a second or so... Talk to the tuner and he said it was the 02's not staying heated..
Old Sep 16, 2009 | 10:32 PM
BuyAmericanIron's Avatar
When I got my truck tuned, the O2 sensors were very lazy at idle. They would go rich, stay there for a few seconds, then go lean, stay there for a few seconds, etc, etc. If you bring up the idle to around 1500, they would function faster or what is considered more normal. After a while, this would turn on a check engine light. He also recommended the 13111 O2 sensors and said he had read numerous articles telling about these sensors helping with the longtube/lazy O2/check engine light problem. Let us know how it works out.
Old Sep 16, 2009 | 10:33 PM
outlawz2004's Avatar
I am having the same problem off and on, I have been putting it off long enough, I need some new ones.LOL. It just stumbles on the idle every now and then, usually more often if the AC is on, but straightens itself out pretty quick. Mine have 130,000+ miles on them,so they are due for replacement anyway.
Old Sep 16, 2009 | 11:08 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, could be the O2's...if they're getting lazy like BuyAmericanIron's but not enough to trip a code, that would be it
Old Sep 17, 2009 | 06:25 PM
hmm makes since. I have a nelson tune on it for all the current mods i have including the headers.
Old Sep 17, 2009 | 06:30 PM
Where is the best place to buy them? Im gonna go to advance autoparts tonight, and see about getting a set. If i get them in this weekend i'll let yall know it it helped any
Old Sep 18, 2009 | 11:29 AM
budhayes3's Avatar
PT's Slowest Truck
I think that most guys just get them locally, like Advance, AutoZone, O'Reilly's, etc.
Old Sep 18, 2009 | 03:24 PM
just picked a set up at advance autoparts. man did i got a hell of a deal i got both of them for 78$ idk if it was a comp. error or what but sure beats 90$ a piece for the truck ones!!! talk about a long harness!! i bet there 3 1/2 ft. long!! i noticed the housing on the sensor is quite abit larger as well..
