the corsa tip on the catback
Old Jan 27, 2004 | 11:37 PM
Default the corsa tip on the catback
for all you corsa guys,
does the tip tuck up next to the sheetmetal very close? in this one pic on their website it looks like it hangs down way to far. IF i end up getting a corsa maybe i can just sell the tip and get a regular stainless tip welded up....
thanks
Old Jan 28, 2004 | 05:50 AM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Not sure about the Corsa, but I know with the Magnaflow I bought, you assemble everything but leave it loose, then you hold the tip where you want it and tighten everything up. At first mine was actually touching the bed, but the instructions said to leave at least a half inch so that any heat would not damage the paint. I just untightened the bolts and repositioned it and re-tightened them. I'm sure that most cat-backs are the same, and I know that the Corsa has a Sweeet tip on it, so I wouldn't change that.
Old Jan 28, 2004 | 08:35 AM
2nd Sierra's Avatar
yeah you can adjust the tips to the angle you prefer
Old Jan 28, 2004 | 01:58 PM
marc_w's Avatar
I second (or third) that...
The corsa system is pretty adjustable. I ended up tweaking the back hanger for an even closer fit to the body work. On the Avalanche, it's already pretty close though.
Old Jan 28, 2004 | 03:11 PM
KeukaZ71's Avatar
the corsa tips look exspensive
Old Jan 28, 2004 | 03:48 PM
11 Second Club
$250 a tip..i
'02SOMz28
Nov 2, 2015 05:47 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
