Cooling problem with e-fans and 34" radiator
Old May 28, 2005 | 11:09 PM
  #31
(Ken)-Blown-383 4x4's Avatar
Originally Posted by thunder550
OK did a few test runs towing up the hill...here's how they went
1st run: PCM wire manually triggered, no a/c
2nd run: PCM wire manually triggered, a/c on
3rd run: Fans triggered by PCM, a/c on
There was almost no difference between the three pulls, all three times the truck got up to 225 or so. Damn, eliminated the easiest fix. I'm going to replace the t-stat next week and see if that helps. Is one t-stat as good as the next? Can I go get one a Autozone or Checker or should I get an OEM? I don't want a lower temp thermostat...started a thread awhile back asking the advantage and the conclusion seemed to be that they will do more harm than good unless you have a multi-core radiator to support the lower temps. I want to stick with the original temp t-stat.
https://ls1tech.com/forums/showthread.php?t=314872
Ken - I see the flaps now, I am retarded sorry.
Highly recommend the Robert Shaw High-Volume Thermostat...
Also, again recommend you go with a 180 thermostat....don't recommend the 160 at all...opens way to early.
Ken
Old May 28, 2005 | 11:17 PM
  #32
Ken
Old May 28, 2005 | 11:50 PM
  #33
parish8's Avatar
single digit dreamer
160 stat holds the temp in the 170's. i really dont know the best temp but for a boosted set up i like the 160 stat. the whipple even comes with a 160stat.
Old May 29, 2005 | 06:09 PM
  #34
thunder550's Avatar
High on diesel fumes
Originally Posted by 02denali
did you ever check that upper hose. i would do that first. that sucker caused me a few headaches.
Yeah I did, when I squeezed it though I got solid water flow, no gurgling or anything. Let it sit for a little bit, level in the overflow tank never went down.
Old May 29, 2005 | 06:13 PM
  #35
thunder550's Avatar
Well, maybe I will go with a lower one later, but for now I want to stick to changing one variable at a time. If I change the stat and keep having the same problem then I have eliminated it as the cause, but if I put in a low temp stat and still have the problem then I don't know if it is the lower temp causing the stat to run open loop. Controlled experimenting.
Keep in mind that I am in Phoenix....will be towing up hill in 115 degree weather before the summer is over, dunno if that makes a difference or not...
Old May 31, 2005 | 12:46 AM
  #36
thunder550's Avatar
Well **** replaced the stat, no change still gets hot pulling the hill. I just checked the fitting that runs from the top passenger side of the radiator to the overflow tank, it was pretty tiny so I drilled it out, flows lots of coolant now, maybe that will make a difference.
Old May 31, 2005 | 02:23 AM
  #37
thunder550's Avatar
I just saw an ebay auction for a LS1/LQ4 water pump...is that the same one as the LM7?
Old May 31, 2005 | 06:08 AM
  #38
one03sierra's Avatar
Formerly one92rs
Talking
if it is for an ls1 the top water outlet will face the rad. if it is for an lq4 or-4.8-5.3-6.0 then the outlet will be turned upwards towards the hood.
Old May 31, 2005 | 08:41 AM
  #39
thunder550's Avatar
Same water flow?
Old Jun 2, 2005 | 06:43 PM
  #40
z7199's Avatar
I have been having all the same problems you have been having only gets hot sometimes. I thought it was the clutch fan so I bought the e-fans didnt help. Bought a new t-stat didnt help checked the hose looked good. I am now going to buy a radiator and sending unit see if that helps. Then I am going to buy a water pump. Is there any thing else that it could be?
