Compression Ratio
Old Mar 14, 2006 | 03:20 PM
Flyer's Avatar
I can give you all that except the valve events. I don't have that information.
Old Mar 14, 2006 | 03:41 PM
vanillagorilla's Avatar
The cam company can provide that for you. You can get the valve events if you know the ICL the LSA and the duration and how you want it timed with the crank. I'll calculate that too if you want. I'm a junky when it comes to building engines on paper.
Old Mar 14, 2006 | 04:18 PM
Well in a 408 with a 6.125" rod a 4.060 gasket bore, a .035" gasket, a 76cc combustion chamber, a 7.5cc piston dome that puts you at about 12:1 SCR.
You'll need a cam with an IC point of about 66* ABDC at .050" lift to get your DCR down to 9.5:1. Translation: Big *** cam
Old Mar 14, 2006 | 05:36 PM
BigBlockChev572's Avatar
Originally Posted by Flyer
Anyone think that 12 or just under would be to much for pump gas?
A 12.5:1 SCR would be ideal. I wouldn't go over a 9:1 DCR though.
Old Mar 14, 2006 | 07:27 PM
Flyer's Avatar
OKay ... you're dead on the 408, but you missed some details.
Heads will be 72cc, gasket will be .030, and the piston will be -2.
ORRRR
Heads will be 66cc, gasket .040, and -2 pistons.
The idea with the first setup is that I can change pistons and head gaskets at a later date and drop the CR a good bit for some positive manifold pressure.
Old Mar 14, 2006 | 07:29 PM
Flyer's Avatar
Define big *** cam.
I'll tell ya how close you are to what I'm looking at.
Old Mar 14, 2006 | 07:34 PM
bluecajun5.3's Avatar
11 Second Truck Club
i think i'd do 10.5:1 w/ my DD 5.3...
Old Mar 14, 2006 | 08:08 PM
treyZ28's Avatar
How big is your bore? thats important.
Old Mar 14, 2006 | 08:40 PM
Flyer's Avatar
408 = 4.030 bore x 4.000 stroke
Old Mar 14, 2006 | 09:17 PM
treyZ28's Avatar
shouldn't be that bad then.
I think 12:1 or even 12.5:1 is just fine provided you dont tow anything
