Comp Cam XR288 in an Gen III 5.3L (LM7)
Old Dec 5, 2011 | 07:27 AM
pjku79's Avatar
Default Comp Cam XR288 in an Gen III 5.3L (LM7)
I just bought a 69 firebird with a broken engine. One of the valves floated and punched a hole in the piston (also turned sideways so the engine couldn't turn). I pulled it a parts, replaced the bad parts and pulled the cam today. I noticed it is a original GM cam that has been regrind. The GM cam says its from 2001. I don't know when it was reground. The cam is stamped with XR288.
When i search it all I can come up with is a cam for a big block. Is it possible this will run in a 5.3L? What are your thoughts on if how this will run?
BTW, my guess is the valve floated because they left the original truck heads with valve springs in. I plan on getting a set of LS6 springs.
Thanks for your help.
Denali08
Aug 9, 2015 04:34 PM
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
Suburban2500
Jul 19, 2015 04:50 PM
