Comp 212/218 high lift questions
Old Nov 29, 2010 | 05:13 PM
BlackGMC's Avatar
Resident Retard
i am putting a 220/224 .581/.581 115+4 in my LQ9... I am basically looking for the exact same results you are. I will let you know how it works out in a few weeks
Old Nov 29, 2010 | 05:43 PM
skyhighsami's Avatar
no title here
I don't want much lope at all. If it sounds a little meaner than a stock escalade with the 6.2 I will be happy. Should I run manifolds or could I use the stock manifolds until I decide which headers I want? Would 1 3/4 be ok or should I consider a stepped 1 3/4 to 1 7/8 or a 1 7/8? Does anyone have a clip of this cam in a 6.0? All I can find is low lift which is on a 112. One more thing, what converter?
Old Nov 29, 2010 | 07:39 PM
OL' MAN's Avatar
I couldn'd tell ya about the stock manifolds, Cus I put 1 3/4" dynatech LT's w/ catted true duals on mine before the cam. I ran it about 6 months NA, with a TRT2600 yank convertor, and loved the performance, but it was way too load w/ two 18" long magnaflows out the back, but damned strong from idle to +/-6,500 rpm if you could stand the noise at WOT. After I put the charger on It got even louder! So I put on a 2 1/2" in/2 1/2" out third muff on it and killed the HP and TQ. To tell ya the truth, i'm thinking about pullin' the dualin/dualout and just do a 3" x-pipe and live w/ the noise!
Old Nov 29, 2010 | 08:10 PM
matt29201's Avatar
alot of guys like the low lift 212/218. i have a friend with the higher lift version in his lq9 and the lope is only slightly noticeable from the rear where the exhaust exits and it has plenty of power to fry the tires and he is just running the trailblazer converter. imo that cam will do what you want it to do.
Old Nov 29, 2010 | 08:49 PM
budhayes3's Avatar
PT's Slowest Truck
A Vinci trucker in a 6.0 won't lope at all if it's properly tuned
Old Nov 29, 2010 | 11:58 PM
low_chevy04's Avatar
So reading in the first page will the high lift version be fine for a 5.3 or not? Also with the high lift version should you run ls6 springs or bigger ones?
Old Nov 30, 2010 | 12:30 AM
jrmchevyman's Avatar
People do run the LS6 springs on the Comp Cams XR265HR-15 212/218 .558"/.563" cam. If you wanted to you could go for some pac1218 springs.
Old Nov 30, 2010 | 03:07 AM
Well the person i'm buying the comp xr265hr from is running the ls6 springs and it seems to work for him with it. anyone know if you need longer push rods or just buy some hardened 7.4 ones for the extra insurance...
Old Nov 30, 2010 | 07:20 AM
Tootall's Avatar
LS6 springs (yellow) will work . . . but I would run the PAC 28-1218. They're good for .600 lift. You're going to want a bigger cam later on. You'll be able to shift at 6500-6800 with no worries about seat pressure . . . . . but don't take my word for it . . . seeing how I'm some ******** and all !
Old Nov 30, 2010 | 09:59 AM
02'Z71ONDUBZ''s Avatar
Exactly what I was thinking. The 212/218 will be a very mild cam in a 6.0 IMO, and the stock converter will be fine. Personally, I think you would be better off with something closer to what blackgmc is going to try. Should idle like stock with that lsa, and would be a good match for a tb converter or tt2600 in a dd. Also, 1 3/4" headers should suffice.
