code P1133
Old Sep 19, 2009 | 10:48 PM
bubbakutz's Avatar
Default code P1133
engine light came on so i ran the code with the scanner at advance auto. it found 2 codes. P1133 and the other said P1133 with a small PD next to it. fuel air metering. i've found little information on this using a search but came up with several things.
a) my front o2's are shot
b) exhaust leaks could cause the code. my y pipe leaks which i need to address but i wouldn't think that would do it since the leaks are behind the o2's.
c) rtv could foul the plugs. i used rtv on the heads behind the headers but i used a very small bead so i don't think that would have made it through either. if it is that, would new o2's get ruined too or is the damage already done?
any input would be great. thanks.
Old Sep 19, 2009 | 11:52 PM
MikeGyver's Avatar
That's the front sensor, bank one, insufficient switching, not a lean code, and only one sensor.
Old Sep 20, 2009 | 08:58 AM
bubbakutz's Avatar
so that means it went bad? i might as well replace them both while i'm at it.
Old Sep 21, 2009 | 10:20 PM
bubbakutz's Avatar
bump.
Old Sep 21, 2009 | 11:58 PM
MikeGyver's Avatar
Switch them out side to side, clear the P1133, and drive it. If P1153 comes up, that is bank 2, and that confirms one sensor is bad.
Old Sep 22, 2009 | 08:37 AM
bubbakutz's Avatar
good idea. thank you.
Old Sep 22, 2009 | 11:59 PM
bubbakutz's Avatar
haven't been able to switch them yet. now the truck is running like crap at idle. rmps are bouncing from 5 to 700ish. sign of the o2's?
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
