code P1133
engine light came on so i ran the code with the scanner at advance auto. it found 2 codes. P1133 and the other said P1133 with a small PD next to it. fuel air metering. i've found little information on this using a search but came up with several things.
a) my front o2's are shot
b) exhaust leaks could cause the code. my y pipe leaks which i need to address but i wouldn't think that would do it since the leaks are behind the o2's.
c) rtv could foul the plugs. i used rtv on the heads behind the headers but i used a very small bead so i don't think that would have made it through either. if it is that, would new o2's get ruined too or is the damage already done?
any input would be great. thanks.
