cleaning ports?
I just hit my ports with some SeaFoam that comes in the aerosol can(called Deep Creep). I just sprayed a little bit, rubbed it with my finger, then sprayed a little more and called it good. I really don't see a need or benefit to have them totally clean...
Berrymans B-12 will remove ALL carbon and oil from ANYTHING!
Spray it on carbon buildup, let it dry then simply use a vacume to suck it all out of the port.
It will turn all flaky if you spray it gently then let it dry.
Won't it also like... blind you and melt your skin off?
BigKID
Jul 11, 2024 05:28 PM
lucas287
31
Jan 12, 2021 06:18 AM
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
