checking push rod length
Old Oct 18, 2012 | 10:27 PM
Boosted_Silverado's Avatar
Default checking push rod length
almost finished building my 408, just need to figure out what push rod length i need.
i have ls3 heads with ls9 cam.
picked up a push rod measuring tool and im not sure 100% on how to use it.
any info on how to measure for push rod length would be awesome.
Thanks guys.
Old Oct 18, 2012 | 10:52 PM
Ferocity02's Avatar
If you got the tool that most of us do, it's pretty simple. Each full turn adds 0.050" of length. Lengthen the rod a little bit at a time, install the rod, install rocker, tighten rocker bolt. Repeat until the rocker is at zero lash right when the bolt is fully tight. Try to get within 1/4 turn accuracy. Then pull out the rod and count the tuns until the rod is fully short. Then do the math: Base length plus number of turns times 0.050" plus desired preload.
For example, lets say you counted 10.5 turns, base length is 6.8", and you want 0.075" preload.
6.8 + 10.5*0.050 + 0.075 = 7.400"
Do this for a couple other rockers to make sure you get the same results.
Old Oct 19, 2012 | 12:25 AM
Thanks for the info, ill figure out what i need tomorrow
Old Jan 18, 2013 | 12:41 AM
I finally got around to measuring my pushrods, I just want to confirm I did it correct.
I got 9 1/2 turns for zero lash, this length is 0.475?
Base length of the tool is 6.8 and I want 0.060 preload?
I ended up with 6.8 + 0.475 + 0.060 = 7.335?
let me know guys, Thanks!
Old Jan 19, 2013 | 02:04 PM
Anyone?
Old Jan 20, 2013 | 04:09 PM
Ferocity02's Avatar
Yup that right! I'd go with 7.350" pushrods for a little more preload.
Old Jan 20, 2013 | 11:43 PM
Thanks
silverstreak07
Jun 28, 2016 06:29 PM
darnie
Aug 10, 2015 10:25 AM
Jake99
Aug 8, 2015 07:56 AM
bizle
Jul 22, 2015 07:31 PM
black6spdz
Jul 16, 2015 01:32 AM
