Check Out My N2O System!!!
Old Jun 15, 2005 | 11:50 PM
01Blackerado's Avatar
Originally Posted by TigerFan187
Holy Sh*t! I just saw that you were going with a STS. Why didnt you go with a Fast LS6 intake and then do a direct port? Dont get me wrong that DP on the truck intake looks sick! I have no doubt that 150 shot wont last long! What are you 1/4 goals? 10's?
STS @ 21 PSI , I didnt go with the FAST LSX because I didnt want to deal with the water pump change, the relocation of the altenator, and the crank pulley along with the belt. This way I can still run everything exactly how it was meant to just with more power!!
Old Jun 15, 2005 | 11:52 PM
STS @ 21 PSI , I didnt go with the FAST LSX because I didnt want to deal with the water pump change, the relocation of the altenator, and the crank pulley along with the belt. This way I can still run everything exactly how it was meant to just with more power!! As far as 1/4 goals...Lets just say I want to give Parish a run for his money!!! Hoping for 9's and I dont care if its 9.999999 damnit
Old Jun 16, 2005 | 12:39 AM
TXsilverado's Avatar
good luck
Old Jun 16, 2005 | 04:07 AM
Bullhead00's Avatar
When will you be running it?
Old Jun 16, 2005 | 09:16 AM
TigerFan187's Avatar
LMFAO! Are you serious? Doing E-fans,LSX intake,putting on a idler relocation bracket,and trimming the water pump wouldnt be much more work since your doing a motor swap and STS! It doesnt matter now becuase you already have the DP setup although I doubt you would have a hard time finding someone to buy it from you! Nice!
Old Jun 16, 2005 | 09:37 AM
good luck
Thank you sir I'm gonna need it if I plan on running with P at all
Old Jun 16, 2005 | 09:38 AM
Hopefully, by the end of this year, I should have everything done That includes suppension work
Old Jun 16, 2005 | 09:45 AM
Yyyyep, plus I had already bought the fuel rails, didnt want to spend the extra money on the machining needed for the new valley cover, didnt want to risk hoses for the pump not fitting, some people have had trouble getting them to seel properly, and I've heard that there isnt that big of a gain for the amount of money being spent on it!! 699.99 for 10-15 hp I just couldn't justify spending it when I got e-fans for 150.00 and it did about the same thing. Plus for 10-15hp I'll just dial up the boost 1 more PSI
Old Jun 16, 2005 | 10:26 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
If you're gonna run 21 psi, you don't need a FAST
Old Jun 16, 2005 | 10:51 AM
Exactly
