???? check engine light
Old May 3, 2010 | 09:39 AM
low_life96's Avatar
Default ???? check engine light
put my cam in first start up the ck engine light was on so i ran the code it sead cranckshaft/camshaft sensor performance????? is that normal?
Old May 3, 2010 | 11:23 AM
Elite67's Avatar
what year and model and wat code i can look it up on service information for you for a possible fix
Old May 3, 2010 | 11:31 AM
00ChevyScott's Avatar
Wearin' da big hat
Did you line up the dots on the timing gears?
Old May 3, 2010 | 12:53 PM
low_life96's Avatar
yea check an duble check em............. its an 02 gmc ill go check the code in a bit
Old May 3, 2010 | 01:11 PM
Wearin' da big hat
Did it just like this?
Old May 3, 2010 | 01:38 PM
low_life96's Avatar
yep! the code is p1336 crankshaft/camshft sensor range/performance that what my dalbo programmer sead.... it runs fine an idles fine
Old May 3, 2010 | 02:21 PM
low_life96's Avatar
would it heart my pcm being a nelson tune if i tryed to relurn the crank sensor with a tech2
Old May 3, 2010 | 04:38 PM
Elite67's Avatar
ill check in the morning for you and let you know what it says
Old May 4, 2010 | 08:57 PM
low_life96's Avatar
Old May 4, 2010 | 09:10 PM
08k1500_3's Avatar
Perform the Crank sensor variation relearn procedure and retest. If the code still sets you screwed up.
