Check Engine code reads misfire in cylinder #7
Old Aug 19, 2009 | 03:59 PM
mudaholicZ71's Avatar
Originally Posted by charcold-bowtie
number 7 cylinder usually dies first. if you want to know....
i hope not!!
i just swapped the plug and plug wire that was on cylinder 7 to cylinder #1 and im about to bring it to the auto store to check the code to see if it switched to #1 instead of #7 and hopefully it did so ill kno its either the plug or wire ill be back in 20 min. and ill update thanx for all the help everyone
Old Aug 19, 2009 | 04:04 PM
turbosilvi's Avatar
Originally Posted by GMCtrk
Im having similar problems with mine but no code is being set off Could be the plugs, wires or coils. I'm leaning towards the coils being bad.
why?
did you test it/them?
stick a screw driver in the boot of the spark plug wire and see if there is any spark when you try to start it. if it does have spark, its a good chance that the coil is fine, if it doesnt spark i would think that the coil is bad or the spark plug wire is bad. replace the wire first. test it again. if its still not sparking, then its your coil. and make sure the connections to the coil are good and have nothing wrong with them... thats my best guess to help with the situation. if anyone has any more info, please add on or correct me if im wrong
Old Aug 19, 2009 | 04:07 PM
GMCtrk's Avatar
Originally Posted by turbosilvi
why?
It only does it at high load WOT. My guess is that the coil is weak. It's almost 10 years old, plus the higher compression of my engine may be making it worse.
Old Aug 19, 2009 | 04:09 PM
TXsilverado's Avatar
compression wont affect your coil.
Old Aug 19, 2009 | 04:13 PM
GMCtrk's Avatar
It will blow out spark easier. So if my coil is weak to begin with, that would be why the spark is going out.
Old Aug 19, 2009 | 04:46 PM
jus got back from advancedauto and even after swapping the wire and plug from #7 to #1 the code is still reading cylinder #7 misfiring. I got the guy to clear the code out and it has yet to come back on. if it comes back on im gonna swap coil packs with another cylinder and take it back to see if its still reading #7 and then go from there. next step would be injector i would imagine and after that valves
Old Aug 19, 2009 | 09:10 PM
CODE4LS1's Avatar
My money is on a clogged fuel rail or maybe the injector has a blockage/bad spray pattern.
Old Aug 20, 2009 | 05:09 AM
What would be the best way to go about cleaning all that? Fuel rail,injector?
Old Aug 20, 2009 | 09:26 AM
pull the fuel rail and injectors. blow out the fuel rail with an air hose and send out the injectors to be cleaned.
has the code come back up?
Old Aug 20, 2009 | 10:47 AM
Yea it came back on this morning. Would I have to send the injectors. Off ot would a localmechanic be able to clean them?
