Cats gone now popping!
Old Mar 12, 2007 | 01:46 PM
rebeldog0085's Avatar
Default Cats gone now popping!
Well I decided that the cats needed to go and replaced them with two pieces of 2 1/2 this weekend. Now the exhaust sounds just how I want it too other than this annoying popping sound at about 2500 rpms. I'm running a single in 3in flowmaster with duel 2 1/2's out the back. What is causing this sound? and what can I do to solve it? I'm thinking about going to a magnaflow muffler or a hooker aero chamber or even doing a single bullet upstream of the muffler but I want to know that it will get rid of this popping!!!! Let me know what you guys think
Old Mar 12, 2007 | 01:55 PM
ramdaspadhye's Avatar
www.summitracing.com
Search for a dynomax bullet
3" in and out, should calm that popping down some.
Old Mar 13, 2007 | 01:54 AM
ricoc's Avatar
Time for a tune. Handjob probally won't cut it either.
Old Mar 13, 2007 | 08:18 AM
I already have a tune, I'm running a hair rich but nothing major.
Old Mar 13, 2007 | 08:27 AM
Yeah, I'd say open the pipe diameter up a little bit and throw you a straight thru muffler on there and that should kill the popping off.
Old Mar 13, 2007 | 10:38 AM
Quik's Avatar
5 year bitches!
the popping is from no cats and youll need to adjust the tune properly to conpensate for it...nothing major
Old Mar 13, 2007 | 11:00 AM
so the popping is because my tune is to rich? So I just need to lean it out, correct?
Old Mar 13, 2007 | 02:58 PM
TXsilverado's Avatar
its always guna pop a little unless you get a good resinator in there. it needs to be tuned a lil after dumping the cats though
Old Mar 13, 2007 | 02:59 PM
12secSS's Avatar
Precisely! Chances are you are dumping extra fuel into your exhaust, this causes the popping sometimes. Hence why F-Bodies heard it when they went ORY. With a proper tune (or re-adjusted tune), it will minimize it.
Old Mar 13, 2007 | 07:32 PM
00stepsyde's Avatar
my truck did the same thing, I had a Flowmaster delta flow, and it was pretty bad around 2500 under normal driving, I put on a Hooker Aerochamber and it was a little worse! I tried having the tune adjusted, just mail order, and could not get rid of the noise. It drove me crazy, so crazy that I went and spent 500 bucks on a set of Pacesetter long tubes and custom y pipe. That got rid of it. Now the truck sounds great. I still have the exhaust in the factory configuriation, y pipe into a single muffler with a single in single out at stock location. Good luck!!
