Catch Can..Made My Own.
Old Dec 2, 2007 | 07:17 AM
joshua022's Avatar
Does it catch it and hold it, or does it route it back to the oil pan or somewhere else???
Old Dec 2, 2007 | 09:06 AM
dirt track racer 81's Avatar
the bottom hole is a drain.
i didnt have all the stuff for the baffling that i wanted but i just took some plate and cut a circle and drilles alot of small holes in it, and welded it in, and below that is another piece that is bent at a 90 and has small holes in it..i was wanting to put some steel wool in between these, but i didnt have any..these piece are about an 1 1/2 or so from the top..i know it aint much but if it dont work i'll make somethin else.. also one question i had for some one that knows more about this than i do. im going to have easch valve cover come into this and go into the back of my intake. is that ok?
Old Dec 5, 2007 | 12:35 PM
BigKID's Avatar
If you want to keep a closed system, that would be fine. Just be sure to use large enough hose to keep good airflow.
ferrellrooster
Mar 6, 2025 03:22 PM
FlyingLow
Nov 24, 2015 10:05 AM
nic351
Sep 24, 2015 09:43 AM
97_ek
Sep 23, 2015 09:16 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
