Cat Back VS. True Duals
Old Oct 8, 2015 | 09:53 AM
thundurchasur's Avatar
Default Cat Back VS. True Duals
Is there a significant difference between a cat back system and true dual exhaust? HP? Sound?
Old Oct 8, 2015 | 10:28 AM
FFDP's Avatar
How much power you are making is a big factor.
For a basically stock motor or a simple cam swap, you should stick with a headers to a Y-pipe and 3in catback.
Old Oct 8, 2015 | 06:41 PM
Wolftrk99's Avatar
Even true duals really need some sort of crossover, been kinda thinking of goin back to a ypipe and turning the ypipe into a sort of xpipe... Just need the time, pipes and patience to make it work......
Old Oct 8, 2015 | 10:42 PM
Thanks both of ya. Sounds like the cat back is where i need to be then.
Old Oct 8, 2015 | 11:13 PM
ezdaar's Avatar
MBRP stainless.
Old Oct 9, 2015 | 08:26 AM
Originally Posted by ezdaar
MBRP stainless.
Thanks, Ezdaar! Pros and cons of aluminized vs. SS?
Looks like most SS systems are 409 SS and it can rust because 400 series stainless has no nickel in it. Given that, it can last longer than coated mild steels but what about performance?
Living in Missouri, we have years without snow and ice and we have years where we get a lot and when we do they salt the heck out of the roads. Has anyone had any corrosion problems with SS exhaust?
Wolftrk99
203
Jun 2, 2016 09:35 PM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
B-_-RAD
Oct 26, 2015 12:26 AM
EmmerichLSx
Oct 7, 2015 08:39 AM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
