Car Craft Little Bro 5.3
Old Sep 1, 2004 | 01:28 PM
  #31
Sport Side's Avatar
I'd have to disagree, putting me "not with stupid"
Old Sep 1, 2004 | 01:40 PM
  #32
marc_w's Avatar
Originally Posted by Jorday
there were a couple of data points in the 2000-2500 rpm range where the engine lost over 50 ft/lbs compared to stock.
Forget THEM!!!
Those are such odd-ball cams. What exactly are they designed for?
Old Sep 1, 2004 | 03:29 PM
  #33
10 Second Club
Yeah, I would probably choose something else if it were me.
Old Sep 1, 2004 | 08:22 PM
  #34
therock's Avatar
Default On the Header Numbers. Your Opinions There? Is 38 HP Realistic?
I have a mildly modded 03 truck to say the least, with only a Nelson 93 tune, a K&N and an SS exhaust. I ponder my next and final step to be a set of TOG long tubes (If they make them in long).
Do any of you experianced folks believe the numbers there?
Would it be so with the SS exhaust? According to Corsa it flows 160 CFM more than the OE? I had my Y-pipe removed after the cats & o2's and have true duals going into the SS muffler.
What kind of mufflers if any was ran on the Dyno in the test?
These headers cost large dollars. I don't want to spend the cash for a small gain.
Old Sep 2, 2004 | 02:59 PM
  #35
tdrumm's Avatar
I re-read the dyno charts and the 50 lb-ft loss was with the GT1-1 cam. I don't think anyone in their right mind would ever consider that cam for their 5.3 based on the durations alone.
But the GT2-3 doesn't look so bad. It gives up 18 lb-ft max compared to stock, and has it all back by 2600 rpm. I'm not saying this is the best cam ever, but with 3000 stall it seems like it would be OK.
As for vaccum, the GT2-3 idled at 800 rpm with 20 inches of vaccum.
Forget the GT1-1, it idled at 900 rpm and had 10 inches of vaccum.
Looks like the engine was tested without an A/C compressor, but with an alternator and power steering pump.
Old Sep 3, 2004 | 07:48 AM
  #36
Sport Side's Avatar
Those duration splits are damn straight ugly.
Old Sep 19, 2004 | 10:02 AM
  #37
10 Second Club
Anyone catch part 2 of the little bro buildup? I just got it in the mail yesterday. They added a set of LPE cnc ported cyl heads with 10:1 compression, 2.000/1.55 valves. Peak hp jumped from 413 to 437 at 6600 rpm, and peak torque went from 369 to 384 at 4800 rpm.
Then, they added the FAST LSX intake manifold with the stock TB, and converted to an F-body accessory drive so the intake/tb would fit. Peak hp then jumped from 437 to 458 at 6600 rpm. Peak torque went from 384 to 392, but the peak torque rpm jumped from 4800 to 5800. The ported heads/LSX intake/f-body accessory drive added 10 ft/lb or more at almost every data point from 2000 rpm all the way to 6800. At 5800 rpm, the heads/LSX/f-body accessory drive was worth 44 ft/lbs. They did say they thought the f-body accessory drive was worth around 6 hp.
Old Sep 19, 2004 | 10:21 AM
  #38
Sport Side's Avatar
Great post Jorday! I was interested in reading the next article. Glad you posted.
This is interesting. They went with a 2 in valve on a 5.3L. Now, I'm curious to know how the bottom end power would have been effected by say a 1.94 intake valve. Maybe globs of more tq.
Whats also very interesting, is how the FAST intake really helped the 5.3L. Incredible.
WAM BAM! The FAST jumped peak power 1000rpm? damn
I can't wait to read it.
also. Cstraub posted this in one of the cam threads.
The law of averages...if your going to give it more of something. . .then something else has to get smaller. Now, with that said, take a stock 5.3 liter engine. If you put more effecient heads on the engine, do you really need a bigger cam.
Cstraub
Hmmm, maybe a stock cammed/ported head combo with a FAST intake might kick some ***. Seeing as how the FAST/Head combo made 10rwhp at the least, from 2000-6800rpm, with the right cam choice, and valve sizes, alot more power could be made. imo
Old Sep 19, 2004 | 10:31 AM
  #39
10 Second Club
I was also just thinking that with 458 hp on the engine dyno you would probably probably be at 400 rwhp or damn close
Old Sep 19, 2004 | 10:38 AM
  #40
Sport Side's Avatar
Very true. But this is a very unrealistic test in my opinion. That cam is still damn straight ugly and killed bottom end. I hope no one ever tries that camshaft. Truly "overcammed"
BUT, those peak numbers are damn impressive by showing potential. Now I'm ready to put together a custom cam/head/intake combo 5.3
