Caprice Freebie
Old Oct 25, 2013 | 08:05 AM
SamuelsonMotorsports's Avatar
Default Caprice Freebie
So I have a buddy who works at a local dealership that had a cop come in with 3,000 miles on a 6.0 Caprice cop car. Apparently, "turn around, don't drown" only applies to everyone BUT police. Long story short, I have a free 6.0 aluminum block, crank, rods, heads, valvetrain ect. A almost perfectly good long block.
He sucked in just enough water to crack 2 pistons and bend a connecting rod, so I could just replace the 2 rear pistons (and 1 rod) and put it up for sale- however I have decided it would be more fun to use some of the parts for myself.
It came with 823 heads (and the offset rockers of course) so what would I need to bolt these into my 02 2500HD? I know that I would need a L92 intake, but what else? Could I use my fuel rails? What about my throttle body and cables? Mine is return, so I know I can't use the stock squareport fuel rails.
Don't worry, I'll put up what I don't use in the classifieds section in a couple weeks. Still debating on using the crankshaft as a lamp since its center drilled, the block as a temporary table (its good, Ill use it later) and of course, sell the front/rear/valley cover/oil pan/cam/afm lifters ect and whatever else I don't need.
I was going to just bolt down a set of 243s that flow 315cfm, but porting a set of 823's to move 350-360cfm seems very very tempting!!! One or the other will be for sale when I finish my stuff.
Old Oct 25, 2013 | 08:46 PM
Guess I'll just bolt down the 243's and sell the 823's. Somebody's gonna want em.
Old Oct 25, 2013 | 08:55 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Bolting the 243s will make it a bolt on deal. All your stuff will fit like factory except for the knock sensors and 58x crank reluctor wheel vs your 24x. Lingenfelter make a 58x-24x adapter and several companies have a knock sensor extension harness.
Old Oct 25, 2013 | 10:55 PM
Oh crap is that how my question reads?
My question was, keeping the LQ4 bottom end and using the square port heads and a L92 intake manifold, what else would I need to make those square port heads work on a return style fuel setup?
If I did use that newer stuff, I would literally ONLY use the block and go buy forged internals, then just take my heads off and swap out the engines. I don't plan on using any of the AFM/DOD stuff, cam, front/rear/top covers, lifters ect. I would machine the block for use with a 24x reluctor wheel crankshaft and "retrofit" it for use in the old 2002.
bfurches
Sep 13, 2014 06:37 PM
bfurches
Sep 11, 2014 08:03 AM
bfurches
Aug 9, 2013 04:12 PM
383k5
Sep 1, 2006 12:23 AM
Scrapin'4.8
Jun 11, 2006 06:37 PM
