Cant Get Passenger Side Pacesetter on!
Can anybody else not get the passenger side on? Ive tried every different way, i can not get it on. Ive tried lifting the engine a few inches, ive tried going through the top, through the bottom. i dont have a lift so ive tried jacking it up the highest i could and sticking it through the bottom but still got nothing. Any Suggestions or ideas? Im kinda out of a truck right now
hey when i was installing my asm's i had to remove the coil pack-valve cover- and cut the bolt on the pass side just below the dryer on the firewall. after i did all that they slid right in.
I removed the tranny cross member. Then lowered the tranny while still bolted to the engine. I still had to monkey with the header for a while and hold my tongue the right way. Eventually got it in place. It was aggrevating though.
Originally Posted by 01_5.3_RCSB
Mine slid right in, no clearance problems at all. I did do mine on a lift though. They slide right in from the bottom. Good luck.
many people had trouble w installing ASM's a while back..but mine went right in. I guess its a matter of how your truck is and how much time you sit back and analyze things.
Perhaps the reason mine went in so fast and without a scratch is because i didnt really have the time to install them at first.....so i just popped the hood and stared at things a few times. Then when i actually had a free weekend, we slid them in.
my website has pictures and descriptions of the LT install if that will help you guys.
www.getonitracing.net then click the tech section on the home page
