Cannot get my knock sensor to read anything.
I have yet to get a reading from my knock sensor. I've been told that after you do the 411 swap like I have that you have to turn it on which HP Tuners cannot do. I have also been told it should work just fine. It always reads 0.0*. I just took a wrench and banged around on the engine and it still read 0.0*. The sensor wire is located at blue connector pin #51. I have a 45* elbow connecting the sensor to the bottom side of the block and no teflon tape wrapped around it. What other than it not getting a good connection (which I would think would throw a KS low voltage DTC) would cause this?
2000 S10 Blazer with a 350 Vortec. I didn't know there were different types of 411 conversions, I followed the one on gmtruckcentral.com.
EDIT: I checked the wire from the pcm to the knock sensor connector (since I had to extend it for the swap) and it's good. Put a ground to the knock sensor and banged around the engine. No reading whatsoever
Yes, just one knock sensor. I have not tried an identical one, just one from my 4.3(different part #), which also said 0 retard. I just snugged it up. I'll see if I have time tomorrow to move it somewhere else on the block.
Okay I know it has been a while, but I thought I'd bump this since I now have time to work on it. So far I've:
I'm at wits end here folks!
- Verified the wire is in the correct spot.
- Tried two different knock sensors.
- Checked for continuity from the knock sensor connector to the pin.
- Hooked a timing light up and banged on the engine, nothing happened. The notch on the balancer is about 1" before the mark on the timing cover though, idk if that matters.
