Can someone points me towards...
Banned
I Would Put The Money In Other Places Do All Bolt Ons First,there Is No Reason For U To Skip The Mian Mods.e-fans,lt's,udp's.
The Only Reason I Have Adjustable Rockers And 1.85 Cause I Have Solid Roller Lifters And My Is Only 525/532 Lift.
U Will See More Gains With E-fans And Pullys Than Rockers
Jmo
Jmo
Originally Posted by 04BlackGmc
Some 1.8 rocker kits for my truck...
Most I see are 500 i was wondering if there was cheaper out there?
Always good to go ahead and replaced Valve springs and Pushrods and upgrade?
here let me counter that build it into the cam theory. if you do it right, you'll do better. vinci put their theory to the test. and here's the results. 03 corvette auto.
comp cams 220/224 .581/.581 115LSA with the 1.7 accelerated lift rockers vs vinci 056 216/224 .551/.551 (1.7 ratio) 113 LSA with 1.8 accelerated lift rockers. which brings total lift to .583/.583.
LS1Tech Sponsor
You are also gaining Duration with 1.8 ratio rockers. There are alot of other factors involved in adding ratio than just the lift. There is absolutly no need to add extra strain to the valve train if you are doing a cam swap you can build all you need into the cam and keep the stock ratio. Changing ratio is for those who want more without having to change a cam.
Nate
Nate
