Can I use 01 vortec 5.3 intake/wiring/etc on an 01 LS1
Old Mar 2, 2005 | 06:09 AM
DMG's Avatar
DMG
Default Can I use 01 vortec 5.3 intake/wiring/etc on an 01 LS1
I have a lightly burned 01 LS1 that is basically a long block. I also have an 01 or 02 5.3 complete with wiring, intake, etc. Can I use the 5.3 manifolds, sensors, etc on the LS1 block and heads? (like replacing a 5.3 long block with a LS1 block and heads)
Will it make decent power? This is getting swapped into something else. Hopefully this is the right forum.
Thanks, David
Old Mar 2, 2005 | 06:13 AM
slammedchevy's Avatar
yes it will bolt right up. if u use you 5.3 heads on the 5.7 you will get more compression to.
Old Mar 2, 2005 | 04:37 PM
DMG's Avatar
DMG
Sweet! I think the 5.3 heads are ok. Do they fllow well?
Old Mar 2, 2005 | 04:41 PM
ngianop's Avatar
What are you putting this mongrel engine into? I heard that the truck intake is taller so if you plan to transplant this engine into a tight compartment, you may want to take measurements before you get too far into this.
axekick
Sep 7, 2015 07:01 PM
nrmskate
Aug 11, 2015 02:44 PM
vmaxpro
Aug 4, 2015 07:02 AM
4B11T
Jul 13, 2015 03:48 PM
Black-Syde
Jul 6, 2015 02:12 PM
