Can header collector gaskets leak sound only?
Old 04-24-2009, 02:30 AM
  #31
Faze2183's Avatar
mine sounds like a sowing machine... but everything ive read up on says its normal...
but while cruzing 30ish mph and higher i dont hear it much... only idle and slow speeds...
i know up around the heads its leakin cause i could only get 4 bolts in there cause who ever had my truck before me must of broken the others or they broke over time... i might just throw a extra gasket on that side or some rtv...
Old 04-24-2009, 02:32 AM
  #32
GMCtrk's Avatar
That leak could wreak havoc on your o2 sensor...making you run rich which can cause several problems over time. I had the same problem.
Old 04-24-2009, 06:53 AM
  #33
PT's Slowest Truck
budhayes3's Avatar
Absolutely, un-metered air can enter the exhaust through suction and throw the O2 sensor readings way off. I'd fix that ASAP. I remember your thread from when you intalled your LT's.
Old 04-24-2009, 04:36 PM
  #34
11 Second Truck Club
fastrt's Avatar
you can swing it by my shop, and we could put it on a lift and look for leaks if you want to. or you and corey could come out and use the lift and weld in the v bands. they will work better to seal and look better than ball joint exaust will. open invite.
Old 04-24-2009, 10:59 PM
  #35
Wearin' da big hat
00ChevyScott's Avatar
What are you up to tomorrow? I'll be busy until 330ish?
Old 04-24-2009, 11:05 PM
  #36
dirt track racer 81's Avatar
have some one rev it up with your hand around the flange..my guess is that you may just be paranoid
Old 04-24-2009, 11:09 PM
  #37
Wearin' da big hat
the only time I actually enjoy driving my truck with the cutout closed is when my windows are up and the radio is on kinda low. Then it actually sounds ok because I can't hear that annoying header sound.
V-bands or bust.
Old 04-24-2009, 11:10 PM
  #38
maybe your just tryin to find a reason to go V-bands.. just do it
Old 04-25-2009, 12:05 AM
  #39
GMCtrk's Avatar
headers sound like ****. How many times have I said that. There's no way around the thin steel of headers. There is a reason stock manifolds are very thick iron.
Old 04-25-2009, 08:32 AM
  #40
fastrt's Avatar
family is down this weekend, and next. you off during the week?
Quick Reply: Can header collector gaskets leak sound only?
