Cams?????
Old Jun 20, 2003 | 03:48 PM
00scsb325's Avatar
Default Re: Cams?????
I have a single stage cam 216 duration intake and exhaust a .524 lift on both and a 114 lsa. I have lost lots and lots of lowend power. But, I can still turn the tires over at a stand still and when I hit 3k it really kicks in hard. I cruise at around 1200-1400 and have no problems, and I have had no tuning done but need it really really bad, it is hard to start sometimes but when started it stays running. I can also chirp the tires at 35mph now (I am a peg leg ). With a five speed you will have no problems at all with a cam, you just down shift for higher rpm's. If you want to take off hard, get the rpm's up before you dump the clutch. Oh, and if you do go over .500 lift you should get different springs, your stock springs would probably hold up for a little while but they would eventually break and that is not good. It all depends on how much you want to gain, and where you want to gain it. Good luck
Oh, and a cam was the hardest decision I had to make so far.
Old Jun 20, 2003 | 05:50 PM
67SS509's Avatar
10 Second Truck Club
00scsb325, what rpm does your cam pull good to and where do you shift at?
Old Jun 20, 2003 | 05:56 PM
hyper's Avatar
Nothing that a little convertor--or "torque in a bottle"-- won't cure!
this is an interesting comment cuz i know the 5.3 beats the 4.8 with the same setup, due to lack of low end umph... but what if u put a 3000 stall on both the stock 5.3 and the stock 4.8. wouldnt the stall skip over the 4.8s weak spot?
Old Jun 20, 2003 | 11:11 PM
00scsb325's Avatar
My cam pulls hard to about 6100-6200 rpms, and that is also about where I shift because I don't have ls1 edit. If I had edit I would shift around 6250-6300. But it also doesn't really kick in hard till about 3k, I also need tuning in a bad way though. I am waiting for stage II heads though before I get tuning done. I have learned that the bigger cam you get the more compression you need, because the larger the cam the less crank pressure you get.
Old Jun 21, 2003 | 01:55 PM
67SS509's Avatar
RED2K & BLACKZ71, what RPM do your Comp cams pull to? Also what valve springs are you using?
Old Jun 21, 2003 | 02:32 PM
I have my shifts set at 5800 rpm with the predator, by the time it shift it runs real close to the 6000 RPM predator limit, so I don't know what it will pull to. I am running 2002 LS6 valve springs (blue). If anybody is planing to change there own cam/valve springs, seriously get a set of keepers, I only lost 3 but I spent 30-45 minutes each tring to find them, with all the skid plates, front diff, drive shafts, its hard to see anywhere.
Old Jun 22, 2003 | 01:24 AM
just run the cam i am running. the f1 cam 591/569 230/226 with a 112 lsa. but then you have to do a lot to the motor to hold up. Also this is not really recommended for a daily driver.
Old Jun 22, 2003 | 01:27 AM
RED2K's Avatar
6300 and the blue 2001 zo6 springs
Old Jun 22, 2003 | 08:03 PM
67SS509's Avatar
Thanks for the responses guys. I'm building a 2001 6.0 to go in a scsb 2wd. Guess Im gonna try the 212/218 .522/.529 114 Comp cam. I'm hoping in the 6.0 with LS6 heads it will pull to about 6000 RPM's. Any opinions on this?
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
