Cams
Old May 2, 2005 | 03:18 PM
b0b's Avatar
b0b
Question Cams
Ok, I am looking at cams for a 5.7 vortec. I dont want lope or a rough idle, because I may be running it with a Magna. The one thing I need to know is, are vortec's considered "roller motors"??? If so, will only a roller cam work. I need directions on what kind of numbers Dur/Lift to go for. I only need power from idle-5000 also. Please help!
Old May 2, 2005 | 04:51 PM
Richard@WCCH's Avatar
FormerVendor
What size engine do you have?
If your engine is a 5.3l, then I would recommend staying under 208º and keep the lobe centers between 112º and 114º. Choose the wider lobe center if you add the Magnuson. All the LS- based Vortec engines (since 1999) have a hydraulic roller cam and lifter assembly.
Richard
Old May 2, 2005 | 08:50 PM
b0b's Avatar
b0b
I have a 1997 5.7L vortec. Im prolly not gonna run a Magna, and go with spray, and some new internals instead. For all you 99-up guys with 4.8's-6.0's the Magnas are great. They are intercooled and they are a Radix MP charger. HP increases are 63%-125%. The kit for the 96-00 5.7 is an Eaton knock-off roots blower, & its non-cooled. My plan is 50-100 wetshot, headers, cam, intake, possibly heads, and some kind of tuning. All that on a SBRC 2wd. I know Im just another new guy asking loads of questions, but I need cam advice, and also any help with a good ecu tune that will work with the nitrous. Also, what about fuel system upgrades with nitrous. Some tell me, it is essential, and some say your stock system is good up to like 150shot. PLASE reply.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
