Cam vs Procharger Costs
Old Dec 8, 2025 | 05:45 PM
therock's Avatar
Default Cam vs Procharger Costs
My Nephew wants to install a mild cam into his 2016 Sierra. His words are "A little bit better cam".
All said and done comparing a cam change and all required along with it, to bolting on a Procharger would the cost be? Which would be more?
Thanks
Old Dec 8, 2025 | 07:23 PM
terravast4's Avatar
Thanks
a pro charger definitely more expensive than a cam install. Depending on what pro charger you get you may have to upgrade the fueling. Also a tune for boost is a lot more than a tune for a cam
Old Dec 8, 2025 | 09:12 PM
RDF1's Avatar
DuNnO
5 Year Member
Cheapest Procharger setup for a 2016 5.3 looks to be $7350
Cam/DOD delete and such usually goes for about $2000
Add labor and tuning to both varies.
Old Dec 8, 2025 | 09:18 PM
therock's Avatar
Thanks, I have not looked at the market in a while.
Old Dec 9, 2025 | 08:27 AM
Pennywise67's Avatar
5 Year Member
I went with a Procharger ( and a cam also) on my 2000 suburban when i swapped in a LQ4. The kit back then ( 2020) was around $5500 for a upgraded D1SC. Plus i did injectors ,fuel pump and gauges. I installed it my self in less than a day. So labor you can avoid for it. But the upside is you get allot more out of it than just doing cam only. My tuner here will dyno tune me for around $300, Check with Bob at Brutespeed he gets the best pricing i have found on PC kits, pus he is a wealth of knowledge.
Larry
Old Dec 9, 2025 | 10:50 AM
BlkBetty's Avatar
Registered User
i have a D1SC system that i am putting up for sale soon since i just upgraded to an F1A if your interested. i was maxing out the D1SC and converting to a 416 stroker.
Old Dec 9, 2025 | 10:56 AM
BlkBetty's Avatar
Registered User
you won't need to upgrade the fuel system if you stay 7-8 lbs or under so a 4.25 pulley or larger. and unless you put in a forged bottom end you won't want to go above that amount of boost. i was getting 6-7 lbs with my setup living at 8000ft above sea level and had 550 rwhp. i loved it! i have been putting together a budget for a while to do a rebuild and that's why i'm selling it, not enough boost lol
Old Dec 9, 2025 | 11:07 PM
therock's Avatar
Thanks, Trying to get him to look at a Maggie. How are the canned tunes doing on them these days? Is there tune dial in support after the sale with scan logs and such?
I was the first to put a maggie on the L33 other than Magnuson's shop truck, they kept in close contact with me, they wound up dropping a pulley size for me. It wasn't until a week or so after we finished I noticed an audible knock when gently accelerating from a 40mph cruise. That got dialed in. The 9.9:1 compression was giving them a fit. Been running 8PSI for 140k miles now. She loves it. The 8 & 10 speed new stocker trucks are giving me a fit when they pick on me but I still hold them.
Old Dec 10, 2025 | 01:22 PM
RDF1's Avatar
DuNnO
5 Year Member
as far as i know its just a regular ole canned tune. Lots of improvements can be had with a proper tune.
Jake75
Feb 17, 2014 07:24 PM
slowlsx
Jan 19, 2009 06:15 PM
K05Bowtie
May 30, 2007 10:15 AM
