Cam, valve spring question
Old Nov 11, 2006 | 08:11 PM
dirtyratt's Avatar
Default Cam, valve spring question
I am running the zo6 springs now. Someone told me if i change out the gt2-3 cam I have know to this cam I will need to change my springs again to 918s what you guys think
Comp Cams XTREME RPM HIGH LIFT XR275HR - 222/224 - .566/.568 w 1.7 rocker - 112 LSA
Old Nov 11, 2006 | 10:32 PM
GMC_DUDE's Avatar
The gt2-3 lift is .571/.578, which is more than your new cam, so I don't see why...
EDIT: This assumes you are running the yellow springs and not the blue ones. But since I'm pretty sure the blue springs will not work with the gt2-3 this must be the case.
Old Nov 12, 2006 | 12:52 AM
budhayes3's Avatar
PT's Slowest Truck
I believe that the Comp cam has a faster ramp rate and that's why they recommend the 918's which have more seat pressure than the LS6/Z06 springs. Lift isn't the only thing to consider when chosing valve springs, you also have to factor in how agressive the cam lobe is.
chopperloco
Jul 10, 2016 10:45 PM
chevyl33
Aug 24, 2015 08:21 AM
bizle
Jul 22, 2015 07:31 PM
4B11T
Jul 13, 2015 03:48 PM
Mzay
Jul 6, 2015 11:05 PM
