Cam Swap....Lifters?
Old Feb 1, 2006 | 02:36 PM
moes04silverado's Avatar
Default Cam Swap....Lifters?
Getting ready for a cam swap. Planning changing cam, rods, springs. Has anyone or should I replace the lifters also? I have had mixed opinions on this, some say yes replace, and some so no need to. Im just thinking of the current wear that is on them from the stock cam.
Old Feb 1, 2006 | 02:41 PM
Zick's Avatar
How many miles on old cam?
Old Feb 1, 2006 | 02:56 PM
FarmerBeau's Avatar
Sexy Party Mod
I would say if you are anywhere under 100,000 miles i wouldnt mess with it cuz its too much work involved. These are roller tappet lifters in these motors. This means that the lifter does not have to mate up to the lobe like the traditional flat tappet cams in small blocks. There is virtually zero friction between the lifter and the cam lobe so unless you are running with a ton of miles, like i said, just leave it alone.
Check this site out, itll help you a lot with the swap. I used this site and the swap went very well.
http://www.ls1howto.com/index.php?article=23
Old Feb 1, 2006 | 03:03 PM
TRUCK CURRENTLY HAS 74800 MILES ON IT. IT WAS HIGHWAY DRIVEN FOR 2 YEARS AND NOW IS A PROJECT.
Old Feb 1, 2006 | 03:05 PM
FarmerBeau's Avatar
Sexy Party Mod
I wouldnt worry about it then. Go ahead and put the cam in. Im about to do another camswap and i have close to 90,000 miles and im not really thinkin of pulling the head.
Old Feb 1, 2006 | 03:22 PM
RIGHT ON THEN....HOW DO YOU LIKE THE NELSON TUNE? IM INVESTIGATING THAT STEP RIGHT NOW, AND DONT KNOW IF I WANT TO DYNO TUNE IT OR OTHER MEANS.
Old Feb 1, 2006 | 03:40 PM
TurboGibbs's Avatar
I wouldn't replace them if they had 200k miles on them, unless I had the heads off. You don't want to pull the heads to just change lifters. Been there, done that.
FarmerBeau's Avatar
Sexy Party Mod
I abselutely will swear by my nelson tune. Free updates for life! You will like the things he can do. Dont screw with a dyno tune. I am gonna get him to do a ride in tune and its way better (from what i understand) than a dyno tune.
Old Feb 1, 2006 | 04:00 PM
JimS's Avatar
I have a Nelson tune and I like it fine BUT..... If I could get a dyno tune that would be much better. There's just none available around these parts. A dyno tune is more accurate and custom done to what your engine likes. MUCH better than a mail order tune even though Nelson does a great job... for a mail order tune.
Old Feb 1, 2006 | 05:38 PM
virgils4.85spd's Avatar
Default Dynos are better
Dyno tunes are more effective. Theres no "guesswork" involved.
Derek
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
