Cam & Spring Half way there!
Just walked in from the garage. New cam is in the motor. Springs and stuff yet to go. Only about 3 hours to get to this point.
A real scare pulling the old cam out. About a quarter of the way out we hear this clank clank.... damn $%#%# was the first thoughts
Slid the cam back in and went to each lifter with a pushrod and they are still there. PHEW! Now what the heck made the noise
Pull the rag out of the front timing cover and the timing chain had slide down into the oil pan is what we heard. For about 5 minutes was certian we were going to have to pull the heads to dig out a lifter. So far so good, just hope the spring install goes well and can get the darn crank balancer on smoothly and torqued right.
I just read the ls1howto.com article on the cam swap becasue I will be doing one in the near future, so if you don't get a special lfter tool, and one of them falls you have to take the heads off??? That suxs, anybody know who sells those pen magnet things?
Originally Posted by 02denali
on the crank pulley the auto parts sells and installation tool for that. i had to cut the main body on mine to get it to work.i think i payed 25.00 for the whole kit.
I have read to many posts of guys with blowers spinning their crank pullies. Its all in, started right up, took a 30 mile drive to get it to "lean" to idle again. Not enough driving to report on how the cam is performing. Does seem to pull much better 4500 to 6000.
Originally Posted by Naked AV
My guess is you hear a little more action under the hood as well....I had a nice 'whirr' going on with more air into the motor. Very nice....keep us posted as you know more.
Under power you can hear the blower of course, but getting that good header sound now. The exhaust note at WOT is awakened. I think its the 4 degrees advance putting power down in the lower RPM's. One thing to note. With a 3.25 pulley, before cam I was pulling 8 psi boost,steady. Cool evenings would see almost 9 at shifts. Now at 6.5 psi boost. She is definately breathing better!
Thanks for the advise on the cam, I love it!
lxcoupe
Jul 30, 2015 02:42 PM
signguy62
Jul 27, 2015 03:42 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
