Cam selection for the LQ4
Old Sep 4, 2011 | 03:59 PM
Thumper215's Avatar
Default Cam selection for the LQ4
looking to throw a cam in my 00 1500 with an LQ4 6.O standard bore
Mods consist of the usual for a DD: LT's, CAI, 2.5 Y pipe to a Flowmaster Daul 3" tips. 3.42 gears. Jasper stage2 2800 stall (will be upgrading). I am sending my 317's out for 5 angle p&p and full valve job. Cam recommended to get this thing moving goes as follows...
Option #1 223/227 .610/614 112
Option #2 238/244 .605/.612 114+2LSA
Having trouble deciding, but I want a powerful run not requiring boost.
My build has come to a stand still!
Old Sep 5, 2011 | 07:57 AM
smok'nZ's Avatar
MASS seller approved
Option 1 would be if I didn't want people to know it had much done to it option 2 would be nasty in a 6.0 I almost bought one for mine
Old Sep 5, 2011 | 08:04 AM
Amedee's Avatar
Option #1
Old Sep 5, 2011 | 11:47 AM
Thumper215's Avatar
Yeah, I am leaning more towards opt. 1. I think the specs for opt would work better with a lighter vehicle.
Old Sep 5, 2011 | 11:51 AM
06Sierra2's Avatar
option one because you have a small stall and not the best flowing exhaust with the smaller y pipe (2.5 vs 3") and flowmasters
Old Sep 5, 2011 | 12:50 PM
Thumper215's Avatar
I have LTs to go on my exhaust and will be having my exhaust redone once I complete the swap. Also will go to a 32-3500 stall. Thanks for the input guys.
Old Sep 5, 2011 | 01:04 PM
06Sierra2's Avatar
oh well that would help out and allow for a larger cam but i would still go with option 1 as the other is a little too big IMO. With the larger stall and better flowing exhaust/heads you have planned you could go with something in the low 230s though
Old Sep 5, 2011 | 01:25 PM
GMCtrk's Avatar
Why is there nothing inbetween the two choices? I essentially run the same exact cam as option 1, and I can tell you it's very mild in a 6.0 and dies off up top rather quickly. I'd go with a cam in the low to mid 230s myself, and probably seeing myself making that change here soon.
Old Sep 5, 2011 | 04:51 PM
budhayes3's Avatar
PT's Slowest Truck
Who's grinds are those, they look familiar? I like the first grind for my LQ9 which would be going into a 99 rcsb 4x4 which is my daily.
First thing that I would do is lose the 3.42's...also, what size tire are you running and what are your intentions for the truck and your goals?
Old Sep 5, 2011 | 05:21 PM
Mangled03gmc's Avatar
Baltimore Whore
Look a little big on the duration for a 2800 verte, but with a 3600 would suffice
