cam recommendations for a 4.8?
Old Nov 12, 2019 | 07:48 AM
IJustWannaGoFast's Avatar
Registered User
Default cam recommendations for a 4.8?
4.8 with 1 3/4 long tubes & a servo, want to put a cam in it just not sure what size to go with i dont want to build a monster just a fun aggressive daily
Old Nov 12, 2019 | 02:11 PM
Summitracing's Avatar
LS1Tech Sponsor
The community can help you pick a cam, but we will need some more info.
What is the year of the truck and is it RWD or 4WD?
Does this have VVT and AFM/DOD?
If you have VVT and AFM are you wanting to keep that or are you getting rid of it?
Are you wanting a drop-in cam without changing valve springs? Do you know the mileage on the engine?
Are you using the stock torque converter and gears? Are you willing to change those?
The more info you provide the better we will be able to provide a camshaft recommendation.
Old Nov 12, 2019 | 03:47 PM
FFDP's Avatar
Yes, please answer all the above questions so we can better help you. Year/make/RWD/4WD etc etc.
Old Nov 13, 2019 | 07:41 AM
firebladeJJ's Avatar
Goals also..
Old Nov 13, 2019 | 11:23 AM
Alvin@PCMofNC's Avatar
Truck Sponsor
Our Stage 2 cam (link) would work well for that. It's a cam that is mean to work with headers but retain a stock stall. We've been moving a lot of truck cams lately which is cool. We spent a lot of time on the specs and local development, good driveability and low end power is important to us, especially in heavier street/daily drivers.
Old Nov 14, 2019 | 08:33 PM
madmann26's Avatar
Let’s be real,
We’ll make our recommendations and you’ll still put a donkey d!ck cam in it.
Old Nov 15, 2019 | 12:39 PM
ZO6Ted's Avatar
Originally Posted by madmann26
Let’s be real,
You just had to didn't you? Something that will cut a 2.7 60' but pull hard as hell from 5800-7500? You're bad lol! Sorry OP...
Old Nov 15, 2019 | 01:03 PM
madmann26's Avatar
I am an *******, I freely admit.
@stock48 @03sierraslt can make a great cam recommendation for a rockin idle, cut on a 106-109 LSA, have great off idle pull but more times than not, guys will go get a ms4 cam and wonder why the fkn tires won’t roll over with their 2k stall.
Tell me when I’m wrong.
Old Nov 17, 2019 | 03:23 AM
03sierraslt's Avatar
you need to answer some of these questions for a suggestion to be made.
Old Nov 18, 2019 | 06:40 AM
MikeGyver's Avatar
Join date November 2019
1 post
You guys scared him away.
