cam lift help please
Old Jul 24, 2005 | 08:21 PM
joelvette's Avatar
Default cam lift help please
im normaly over on ls1tech, but since i bought a 6.0 (lq9 not lq4) for my 73 firebird i thought id ask you guys im putting an ls6 intake, longtubes, 4l60e on it and was wondering whats the max lift you can safely go to with the lq9 engine? right now i plan on running the stock rockers, valves, mild porting, 918's. not to be a drag car but a strong street/ daily driver. any cam/torque conv suggestions welcome thanx for any info joel
Old Jul 25, 2005 | 10:46 AM
BigKID's Avatar
With those 918 springs I wouldn't go over .580 even though they are rated to .600. As far as piston to valve clearance limitations, you can easily go .610-.620 on unmilled heads with stock valves and a good set of dual springs depending on duration of the lobe.
Old Jul 25, 2005 | 11:26 AM
white1's Avatar
I'm more daring I guess, I wouldn't be scared to go .600 with my 918's as long as the rpms were kept relativly low ~6500 or so. But Big Kid is probably right. Just to be safe, stay around .580 or so.
Old Jul 25, 2005 | 11:55 AM
joelvette's Avatar
thanx guys and i was worried about a 551 lift. i just wanted to make sure the pistons and valves dont try to cross pollinate. joel
LARRY01Z28
Aug 1, 2015 10:15 PM
Castro45
24
Jul 31, 2015 07:13 PM
Kaldar
Jul 27, 2015 06:42 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
