Cam installed, got some codes.
Hey guys, I got the cam installed and it was running fine with no service light. I did a few high rpm runs up the highway and the exhaust blew off from the headers. I haven't had a chance to fix that yet, but since that happened, I come up with these codes.
[PCM] P0153 - HO2S Slow Response Bank 2 Sensor 1 (Old) (Current) (Immature)
[PCM] P0174 - Fuel Trim System Lean Bank 2 (Old) (Immature)
[PCM] P0704 - Clutch Switch Input Circuit Malfunction (SES) (Old) (History) (Current) (Immature)
[PCM] P1153 - HO2S Insufficient Switching Bank 2 Sensor 1 (Old) (Immature)
[Brake] C0281 - Brake Switch Circuit (History)
[Brake] C0237 - Rear Wheel Speed Signal Erratic (History)
[Brake] C0236 - Rear Wheel Speed Signal Circuit Missing (History)
[Brake] C0238 - Wheel Speed Mismatch (History)
[Unknown] B2961 - (History) (Immature)
[Unknown] B2647 - (History) (Current) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Complete
Heated Catalyst: n/a
Evaporative System: Complete
Secondary Air System: n/a
A/C System Refrigerant: n/a
Oxygen Sensor: Complete
Oxygen Sensor Heater: Complete
EGR System: n/a
Are these codes connected with the fact that the exhaust isn't completely together? Will it hurt with me driving it like this? I have to order some flowmasters and redo the exhaust. Little too loud with no cats and straight pipes. Thanks for the help. Tim
Continuous Tests
Misfire: Complete
Once Per Trip Tests
Catalyst: Complete
EGR System: n/a
The O2 sensor response and fuel trim codes are probably a result of the exhaust blowing off and the O2 sensors getting incorrect readings...or you have a bad sensor. The brake and speed sensor codes are ABS codes that could have been caused by a couple of different things. The other 2 codes are body (BCM) codes, not sure what their description is though...
You might have an open circuit or something with the clutch switch causing the P0704
The cam is a texas speed 228r. Specs are 228/228 .588/.588 112.
As for the insufficient switching, it hadn't happened before the cam install, but could be a result of the huge exhaust leak at the collectors as budhayes3 said.
all_individual
Jul 13, 2015 11:01 AM
GreyChevy
Jul 7, 2015 08:57 PM
