Cam Install... what to do after installing?
Old Oct 3, 2006 | 11:25 AM
benvortec's Avatar
Default Cam Install... what to do after installing?
I know how to install the cam but my friend said that generally after you install a cam you degree it? I haven't heard any of you talking about degreeing a cam. What is it and is it neccessary?
Old Oct 3, 2006 | 11:28 AM
RoosterMcCandles's Avatar
You can install the cam advanced or retarded. I believe that either one of those can move the power band around and what not but I'm not 100% sure. I saw a chart somewhere on the internet but I can't find it now...
Old Oct 3, 2006 | 11:29 AM
TXsilverado's Avatar
what cam do you have to install?
Old Oct 3, 2006 | 11:35 AM
most likely you just need to line up the dots and go
Old Oct 3, 2006 | 12:03 PM
Nick™'s Avatar
you can advance the cam or retard the cam or install it "straight up" order the cam how you want it and install it straight up, they can grind the advance/ retard into it for you if you get it custom
Old Oct 3, 2006 | 11:41 PM
ScojoDak's Avatar
Degreeing a cam is what most hardcore builders do to insure the cam is ground to their specs. It verifies the valve events (beginning, closing and duration) occur to the builders specifications. Other comments on this topic touched on advancing/retarding the cam. This is done to shift the powerband lower for more torque, or higher for more top end power. My suggestion to the average joe is to install the cam "dot to dot". Most reputable cam grinders that include a "cam card" have ground the cam to the specs shown on the card. Good luck!
all_individual
Oct 10, 2015 10:09 PM
low2001gmc
Jul 23, 2015 05:10 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
ssierra08
Jul 15, 2015 06:40 AM
all_individual
Jul 13, 2015 11:01 AM
