Cam install how much
Ok I am working on buying a cam from hitman. need to know how much it cost to install one of these. I do not have the resources to even try this. I know my truck is a 04 that's why I want to keep it pretty stock internally. How many hours atleast would help. thanks
Ok I have talked to two places one wanted 860 for a install and the other wanted 700. their trying to tell me it will take 10 hrs to install a cam and I told them they were freakin nuts. their geting this info out of a gm go by book. talk about a crock.
I would definately look for someone that specializes in the LS1 rather than someone that plans to use the GM Flat Rate manual. The LS1 does NOT require removal of the heads or intake manifold for a cam install so this reduces the work time considerably over other engines. Be sure they use some method to hold the lifters up(JPR tool, magnets, dowel rod) while the old cam is being swapped for the new one. If a lifter drops the heads WILL have to come off and then your looking at a lot more time. You should do this job yourself. You can put the money you save in labor into a Rollmaster double adjustable timing set and a ported LS6 oil pump and stil have money left over.
Offroadunleashed
Jul 20, 2015 02:25 PM
all_individual
Jul 13, 2015 11:01 AM
